1784-PKTX problems
cwilliams
Jan 2010
Moberly, Missouri
I have a machine at work that has a 1784_pktx card in the PC. The computer is using windows XP Pro as the operating system. The pktx card is not working and is showing error. I understand that I need to install an xp driver because I think when the card was originally installed around 2001 the operating system was win 98. I am trying to find out how to install the new driver in rslinx oem without having to remove the card and do a total reinstallation. Any help would be greeatly appreciated
What version of RSLinx do you have? Does the 1784-PKTX driver show up in RSLinx? You may have to upgrade your RSLinx if its not there.
what is the requirements for replacing a 1784-ktx card with 1784-pktx card to work with the same operating system WIN NT and same interface program
the ktx card is :-
interrupt setting for channel 1 =9
E3 jumper at 16 bit (pin 2&3)
SW3=D
SW4=7
our main problem is finding pc with ISA slot so we are trying to have the PCI card
The User Manual says it is compatible. You will need a Windows driver. They have two separate driver downloads. One is a Windows 95/98 driver. and the other is a Windows XP, and Windows 2000 driver.
I don't know which one you would use. My guess would be the Windows 95 driver since the card initially supported NT and Win95. But I would keep trying drivers until I find one that works.
The drivers and the user manual for the PKTX are available from the RA Download Center.
https://compatibility.rockwellautom...roductDownload.aspx?keyword=PC Card&crumb=112
Good luck. It's been 20+years since I've dealt with Windows NT.
OG
Hey everyone, Ran into an issue on a customer's system a couple times recently and wanted to check if anyone might have any clue what's going on...
1,398
I have and old computer running controlview300 in dos. I’m try to update to rsview32. But the question I have now is getting communication...
2,787
Has anyone tried using a 1784-PKTX in a PCIe slot, using a PCIe to PCI adapter? :scratch:
1,372
Hi, Previously we used SS5136SD DH+ cards for communicating with Allen Bradley SLC 5/04 PLC utilizing Wonderware free SST5136 DDE server. This...
2,848
Hi All, A quick question. I have one Computer with 1784 PKTX Card for interfacing with DH+ Network. One PLC nearby control room has got:- 1. 2...
2,300
