plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 9th, 2010, 05:08 AM   #1
rigicon
United Kingdom
rigicon is offline
rigicon's Avatar
Twido analog input calcualtion
Hi all,
I have an analogue input on a Schnieder Twido PLC.
The sensor measures distance and has a range of 100mm
It seems to only start working at 55mm away and reaches full range at approx 155mm.
So from 55mm I get 0(4mA) and at 155mm I get 4095(20mA)
My simple formula was z =(measured value 0-4095)
(z x 100) / 4095 this gives me a 0 to 100 value call it Y.
Y is its inverse so I have 100 - Y.
This seems to work but on different sizes i need to recalibrate and end up 80-Y or 85 - Y.
The formula is not right somehow although it seems logical to me - i have definitely missed the plot I wish the Twido had scaling.
Any mathematicians available ???
__________________
Artificial Intelligence - Genuine programmers headache
Old February 9th, 2010, 01:51 PM   #2
Lare
Finland
Lare is offline
Hi!
Basic scaling methos is to use formula y=kX+b which you already have used, but take a look to thread http://www.plctalk.net/qanda/showthr...2&highlight=EU and read Tom Jenkins reply to threat.
It's is also maybe better if you reconfigure twido analog module to use raw data values from 0 to 10000 (4
mA =0%, 20mA=100% ) instead of 0-4095. (You can use different raw data values to analog modules if you right mouse click above analog module and select configure => Range = custom...)
It's more easier to understand raw data values 0-10000 than 0-4095, when you use math in twido and you can see better were the error to scaling happens...
Old February 9th, 2010, 02:27 PM   #3
rigicon
United Kingdom
rigicon is offline
rigicon's Avatar
Thanks Lare
Just after the post i found out about the custom scaling I was going to use 0 to 100. But I think you are right 0 to 10000 is better.
This gives me a nice resolution to 2 decimal places.
__________________
Old April 21st, 2016, 05:11 AM   #4
Cspatil_5394
India
Cspatil_5394 is offline
Dear sir,
I am beginner in twido plc please tell me ho to use multiplication.
__________________
Chetan Patil
Mobile- +91 9637138565
Old April 21st, 2016, 05:13 AM   #5
Cspatil_5394
India
Dear sir,
__________________
Chetan Patil
Old April 21st, 2016, 07:03 AM   #6
osmanmom
Malaysia
osmanmom is offline
i guess
Old April 23rd, 2016, 06:34 AM   #7
Cspatil_5394
India
Dear sir,
I am beginner in twido plc please tell me ho to use .
__________________
Chetan Patil
Old April 23rd, 2016, 06:36 AM   #8
Cspatil_5394
India
Dear sir,
I am beginner in twido plc please tell me how to use the MOV INSTRUCTION .
__________________
Chetan Patil
Old April 23rd, 2016, 08:51 AM   #9
osmanmom
Malaysia
osmanmom is offline
maybe correct maybe wrong,
i need to read the user manual more further
Old April 23rd, 2016, 03:08 PM   #10
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
copy the formula out of the help file for the AB scl function.
Old May 2nd, 2016, 01:10 AM   #11
Cspatil_5394
India
Dear sir,
I am facing the following communication problem in twido plc please help me.
when i am going to communication through ethernet then it saying
communication error,Check communication parameter,network cable,configuration and controller supply.
But i have changed the cable but same problem i am facing.
__________________
Chetan Patil
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Scalling for analog input module - SLC 5/04 ckchew666 LIVE PLC Questions And Answers 1 May 15th, 2008 09:31 AM
modicon A120 analog input problems Bart LIVE PLC Questions And Answers 2 December 5th, 2005 01:25 AM
Analog Input to Analog Output rawtalent LIVE PLC Questions And Answers 6 March 22nd, 2005 04:02 AM
DL06 Analog Input Problem shady_yehia LIVE PLC Questions And Answers 9 January 15th, 2005 03:17 PM
AB Analog Input Module Wiring... Eric Nelson LIVE PLC Questions And Answers 3 May 6th, 2002 08:37 AM
