How to give negative pulse to servo motor?
sankz
Mar 2010
Mumbai
please help me
im interfacing servo to micrologix 1200.......and want o make a ladder to drive this servo......trouble is....how can i reverse the motion of servo?
You have not provided enough information to answer your question.
You really need to specify what drive you are using, how it is commanded, how it is wired to the MLX etc.
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
60
I am troubleshooting an actuator which is not responding to the plc code. The range in the channel of the Allen Bradley 1756-OF8 Analog card is...
625
I have 3 koyo PLC's in series. The 1st and 3rd are reporting values correctly but the 2nd is reporting negative values. The values in the PLC and...
1,416
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,115
Hello. I am trying to figure out how to setup a PID in Control Logix 1769 Controller in a way that it would control a drive speed by sending...
1,616
