plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 24th, 2010, 08:48 AM   #1
macgioo2
United Kingdom
macgioo2 is offline
vpn connection to plc in LAN
Hi guys,
I have a question, I want to create a vpn for remote access for maintanance to a plc.
I have a designated broadband connection to the HMI (Windows XP) which has two network cards.
1 for WLAN and 1 for LAN.
The PLC is on the LAN obviously, I can acess the PC WAN remotely but how do I get from the PC WAN to the PC LAN to see the PLC.
Any help or guidance would be much appreciated
Old March 24th, 2010, 10:23 AM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
Why bother with two NIC's ?
I suppose you can bridge between them, but then you effectively have a single network again, so I fail to see the advantage.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old March 24th, 2010, 11:23 AM   #3
mordred
Canada
mordred is offline
mordred's Avatar
sounds like your talking a pass through connection. to answer this question we would need the make and model of the PLC and the HMI
Old March 24th, 2010, 02:07 PM   #4
macgioo2
United Kingdom
macgioo2 is offline
Well the PLC is AB Control Logix 1769 L35E and the HMI is factorytalk se on a windows xp machine.
The pc is 192.168.0.167 for LAN and 192.168.1.169 for WAN
the plc is 192.168.0.159, I can get as far as 192.168.1.169 but I cant see anything after that.
If you need anything else please ask, I'm really stuck with this and I'm on-site with the customer
and will be until its fixed!!
thanks
Old March 24th, 2010, 03:17 PM   #5
MuotioJ
Finland
MuotioJ is offline
Your ip packets dont know where to go
Attached is image that tries to illustrate some of your problem.
There is programming pc you connect by vpn trough internet to that HMI. Those devices between are firewalls and routers, those dont matter if vpn connection is established and working.
What matters is that hmi pc is in two subnets: 192.168.0.x for factory network and 192.168.1.x for (I presume) office network, its the one that is used to go trough to internet.
Now when you ping 192.168.1.169 yout programming pc sends sertain packet on network and then device at ip address 192.168.1.169 answers with ack message to ip of that pc that send ping packet. All is well, as device targetet with ping knows where that sending machine is. So it can reply.
Now when you try to ping 192.168.0.159 the packet does not know where it should go as pingin machine has no idea where subnet 192.168.0.x is.
So what you need to do is setup routes. These must be placed atleast on HMI pc, details depend lot to local application and vpn in use. So I suggest if you have it department, have a call to them.
Old March 24th, 2010, 08:12 PM   #6
Ranjith
Australia
Ranjith is offline
how do you connect to the windows XP PC remotely? Is there a router before the PC? What is the router IP address? All you need to do is to set the router IP address same range as the PLC and PC. EX 192.168.0.1 Then set the gateway address of the PC and the PLC as 192.168.0.1. You will find this as the same place as you set the IP address and the Subnet mask. You do not need 2 network cards on the PC.
Old March 25th, 2010, 01:53 AM   #7
todster
United States
todster is offline
XP shares the same core as Server 2003. You can change a setting in the registry and enable routing services.
HKEY_LOCAL_MACHINE \SYSTEM\CurrentControlSet\Services\Tcpip \Parameters IPEnableRouter = 1 (the default is 0) It's unsupported by MS but it works. You'll just need to set up the routes. A reboot will also be required. It's been quite some time since I've used it but it wasn't that hard to do.
Old March 25th, 2010, 02:59 AM   #8
macgioo2
United Kingdom
macgioo2 is offline
Yes I realize that the simple solution is to change the ip of the router so that all devices are in the same range, 192.168.0.xx.
However the customer is adamant that he does not want the plc on the internet.
I have no option but to jump from the WAN to the LAN.
I'm using netsupport to connect to the router/pc from outside.
I don't even know how to route from WAN into LAN!
Is there a handy guide?
Old March 25th, 2010, 03:27 AM   #9
MuotioJ
Finland
MuotioJ is offline
Its all about IT security. Does your customer have IT department?
Old March 25th, 2010, 03:34 AM   #10
todster
United States
todster is offline
What you're looking for is IP forwarding. The service exists in XP, it's just not advertised. Googling "xp as a router" or "routing with xp" is one staring point for setting up. You can also look at the docs for server 2003 regarding the routing service for more indepth configurations.
Old March 25th, 2010, 03:35 AM   #11
macgioo2
United Kingdom
macgioo2 is offline
I'm afraid not, advice I've been given tells me I'm just a few steps away from realizing the concept. But I lack the knowledge to execute.
Question. Is it really a matter for this company. I own the ASDL connection.
I can connect to the router/pc from outside.
I own the PC and both NIC's in it.
I own the PLC and local switches.
The bridge I'm trying to build is between the two network cards inside the PC.
As suggested before, is it not a local route inside the PC i'm trying to create!
Or am I missing the basic concept??
Old March 25th, 2010, 03:52 AM   #12
macgioo2
United Kingdom
macgioo2 is offline
Thanks todster, I think you cracked it!!
http://www.home-network-help.com/ip-forwarding.html
Old March 25th, 2010, 05:34 AM   #13
The Plc Kid
United States
The Plc Kid is offline
The Plc Kid's Avatar
Bob
I think he is trying to use the HMI pc as a Jumpbox http://techrepublic.com.com/5208-128...ontent;leftCol
http://www.derkeiler.com/Newsgroups/.../msg00047.html
We used to have a couple of those setups here.
This http://www.****.biz/is the best solution for a customer like this. Everthing is already done. It is secure and you really do not need any help from the it dept if they customer does not have one.
Old March 25th, 2010, 06:10 AM   #14
mordred
Canada
mordred is offline
mordred's Avatar
http://www.plctalk.net/qanda/showthread.php?t=54154
This thread is similar Ken Roach posted some useful info on how RS linx lite handles TCP/IP
Old March 25th, 2010, 10:52 PM   #15
todster
United States
todster is offline
All Macgioo2 wants to do is communicate with another subnet utilizing existing hardware. He could also have taken any standard $40 DLink wan/lan router and tweaked it to do the same thing. If you're a walmart diehard then don't bother, as their stuff is missing 20% of the features , that's why it cost 20% less, you got what you paid for. There's really no need to buy an expensive dongle to do what he already can do, more cost effectively. If he were to buy something that requires absolutely no intelligence to set up, what would he be implying about himself? What would he have learned, or gained?
Another option would be a multi-nic pc setup headless with no mouse, monitor, or kb. Install the free HyperV core with a virtual 'nix variant (also free) config'd as a vlan. Set bios for auto on if power failure and virtual to auto start on recovery.
The path you choose to go from point A to point B is based on your abilities and perception.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens Step7 remote connection via VPN syphax LIVE PLC Questions And Answers 6 November 13th, 2008 12:37 PM
Remote VPN connection with MP and/or S7 PeterJan LIVE PLC Questions And Answers 1 November 4th, 2008 03:49 AM
PLC connection wz 2 wire Transmitter Amr Muhammed LIVE PLC Questions And Answers 1 April 26th, 2008 11:26 AM
PLC connection wz 2 wire Transmitter Amr Muhammed LIVE PLC Questions And Answers 2 April 26th, 2008 07:20 AM
plc connection chocobo244 LIVE PLC Questions And Answers 0 May 20th, 2006 10:31 PM
