This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Mar 2010
Looking for a little guidance in regard to digging out an installed license number.
I have a process line which has Siemens Step 7 Version 5.1 service pack 1 installed at the Scada console. I need to record the license number associated with this install to kick start a new service agreement with our local reps (support, service packs, etc), and I can't find the license number or where it is recorded in the software. Due to the age of the Installed Step 7, the hard copy and soft copy of the license is gone and my only hope of recording the number is if Step 7 Version 5.1 has some sort of ancient license manager software or batch file/executable i can't find in the Step 7 directory. I am used to using the license manager that is included in versions 5.3 and later of Step 7, which clearly states the license number used for the installed product. Any help on this would be greatly appreciated |
#2 |
![]() Join Date: May 2006
I'm not familiar with older Step7 packages, but you could check your C:\AX NF ZZ folder. (It is hidden by default, change folder options to see it in explorer)
#3 |
There should be a program called Automation License Manager in the computer. In the start menus simatic folder or directly in path ..\Siemens\Automation License Manager\almapp\almappx.exe. At least when using automation license manager 4.0.
There you can see different license keys installed on different hard drives and atleast in 4.0 the number of the license. |
#4 |
Thankyou for the replies
![]() Unfortunatly the version of step 7 that is installed is 5.1, and in saying that, there is no obvious license manager under any of the sub-directories. I was hoping that under C:\Siemens\step7\S7Bin there would be an executable or batch file that would either display or prompt me to update my license number for my install of step 7, but seeing as i have no backup or support, double-clicking on the random executables and having something fail is not a desirable solution. Again thankyou for the replies. |
#5 |
![]() Join Date: Sep 2005
Look for "AuthorsW" inside your siemens installation folder or start menu - the Icon is a Red floppy disc.
On my computer its located in C:\SIEMENS\AuthorsW |
#6 | |
![]() Join Date: Oct 2005
Quote:
These are the actual keys installed for authorization of your software. |
#7 |
Thank you to all who read and replied to my post
![]() I have found that both solutions posted after my last post have pointed me to exactly where i needed. i assumed that AuthorsW was something to do with Authors of program files, not being an Authorisation program. Again thank you very much all, for solving my issue
#8 |
For install old Simatic soft you can use any nonZero number: 111111....
0000.... for Demo mode. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Allen Bradley 1761-NET-ENI | Jezz | LIVE PLC Questions And Answers | 11 | August 17th, 2007 07:56 PM |
| S7-416-2 DP Fault - SFB20 | sparky64 | LIVE PLC Questions And Answers | 8 | July 30th, 2004 02:48 AM |
| Philosophical Illusion? | Terry Woods | LIVE PLC Questions And Answers | 71 | June 28th, 2004 07:41 AM |
| Changing the station number of Step 7 200 PLC | Derek Scholes | LIVE PLC Questions And Answers | 3 | March 25th, 2004 04:50 AM |
| Sequential state machines | kebaldwin | LIVE PLC Questions And Answers | 15 | January 1st, 2003 08:00 PM |
