plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 3rd, 2010, 10:07 AM   #1
bfoss
United States
bfoss is offline
Exclamation MicroLogix 1100 EEPROM Failure
We have a MicroLogix 1100 with Firmware 8.0 that fails to recognize the EEPROM. An error of failure to store to EEPROM 0x4 is displayed when trying to store the program to the memory module. We have gone through steps to power off/on the processor, reseat the memory module and power off/on, tried a second memory module that was working on another MicroLogix 1100 at a second site with same failed results on this processor, verified the original memory moduled worked on the second site's MicroLogix 1100, tried a second MicroLogix 1100 with firmware 9.0 with two different EEPROMs at this problem site. It seams the only item which is the same under these conditions is the PLC program, unless two different MicroLogix 1100s with different firmware (the second being new out of the box for test) both are faulty. Any suggestions on what could cause this?
Old May 3rd, 2010, 11:04 AM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Looking through the knowledge base at ab.com, I see that there was a problem with RSLogix500 version 7.3. There is a patch at knowledgebase ID#52622 or you can upgrade to version 8.1.
The only other relevant note said try reseating it and if that doesn't work to replace it...
What version of RSLogix are you using?
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
"You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway."
Old May 3rd, 2010, 01:03 PM   #3
bfoss
United States
bfoss is offline
We are using RSLogix 500 version 7.30.10 (CPR 9). We tried the reseating of the memory module. I'll take at the referenced Knowledgebase answer, although we do not have this issue with about 16 other MicroLogix 1100s which were all programmed with the same version of RSLogix 500.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How to copy string data to integer as ascii in micrologix 1100? SirScott LIVE PLC Questions And Answers 5 May 6th, 2009 09:51 AM
Micrologix 1100 using an older OPC server to Labview... frenchy LIVE PLC Questions And Answers 3 November 17th, 2008 02:17 PM
Micrologix 1100 - How to mplement this PLC-5 rung? skyfox LIVE PLC Questions And Answers 31 July 31st, 2008 12:38 AM
Cimplicity HMI ethernet to Micrologix 1100 problem jeffdc54 LIVE PLC Questions And Answers 1 August 9th, 2006 04:12 PM
Micrologix 1100 vs 1200 scan times TamHo LIVE PLC Questions And Answers 3 May 2nd, 2006 07:12 AM
