plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 16th, 2010, 06:10 PM   #1
james84
Australia
james84 is offline
Tag addressing in citect scada
Hi Guys,
currently I am working on Citect Scada project where i am using AB plc to connect with SCADA.
now, i am finding problem with addressing tags in SCADA with AB plc tags. i don't know how to find out correct addresses of general bit (general tags created during program) in AB plc and how to implement in SCADA.
if any one know the exact way to connect AB plc with Citect Scada pls let me know.
thanks in advance.
Old May 17th, 2010, 03:21 AM   #2
kellian
Australia
kellian is offline
kellian's Avatar
Citect Version?
PLC Type?
Network type?
Old May 17th, 2010, 07:48 PM   #3
james84
Australia
james84 is offline
citect version 6.00
Plc type : Allen Bradley Control logix
network type: ethernet (IP)
Old May 17th, 2010, 07:48 PM   #4
james84
Australia
james84 is offline
Quote:
Originally Posted by kellian View Post
Citect Version?
PLC Type?
Network type?
citect version 6.00
Old May 18th, 2010, 04:04 AM   #5
kellian
Australia
kellian is offline
kellian's Avatar
Citect can only access controller scoped tags.
for the tag address structure see the driver help for CLX in the Citect project explorer help.
Some basics are
for bit tags replace the "." with "/"
for Array tags replace the "[]" with"{}"
Is this a working project or are you starting from scratch?
Old May 18th, 2010, 04:22 AM   #6
james84
Australia
james84 is offline
Some basics are
it is working program in plc but starting new project in citect scada....
my question is if plc tag "Machine_Running" as a general bit......what would be the address in citect scada for perticular tag..... i can't locate that address in AB plc......
where in Omron you can find address of any tags
but AB is new for me and I can't find address of any general tag....
if u can help me with this would be great...
thanks.
Old May 18th, 2010, 05:08 AM   #7
kellian
Australia
kellian is offline
kellian's Avatar
If Machine_Running is a controller level tag in the PLC then the Citect Address will be Machine_Running of type DIGITAL.
Old May 18th, 2010, 05:25 AM   #8
james84
Australia
james84 is offline
thanks.....
Old May 18th, 2010, 07:20 PM   #9
jack84
Australia
jack84 is offline
thanks for ur reply..
one more question. if tag name in AB plc is
Data Type:
AB:1756_MODULE_INT_74Bytes:I:0
what could be the Name and Address and Data type of this control tags in Scada?
Old May 19th, 2010, 09:47 PM   #10
zankorel
Australia
zankorel is offline
Data Type:
Are you trying to access IO directly?
You cannot create a structure in Citect like you can in ControlLogix. You need to drill down to the bottom of the IO structure and assign that a DIGITAL, LONG or REAL Citect data type depending on what sort IO you are trying to read.
__________________
Chris Watts
Electrical Engineer
Old May 19th, 2010, 10:06 PM   #11
jack84
Australia
jack84 is offline
thanks mate,
so according to my understanding in above example.. adrress would be the same LOCAL:2:I..... and DATA type: INTEGER..
that what you are saying...
if i am wrong, can you please give me a explaination with simple example here...
i would be very greatful, if you can help me here..
Allen bradlley is bit new for me..
thanks.....
Old January 1st, 2011, 10:05 PM   #12
Vazgen
Finland
Vazgen is offline
Hi everyone,
i use of Citect Ver 6.0 and 2 ADAM 4017+(8 analogue input) , 1 4068(8 relay output) AND 1 4520(RS232 to 422/485 converter).
i need 14 analogue input and 8 relay out put
but i can't create more than 8 analoge variable Tags (Ai0 - Ai7) and 4 Relay out put (Do0 -Do3) . when i create Address tag Ai8 or Do4 compiler will has error (Bad IO device variable )please advise me ?
Old January 8th, 2011, 01:19 AM   #13
sh984
Iran
sh984 is offline
Hi vazgen
you have to create 2 i/o device for 2 ADAM 4017+ ,one on for IoDev_4017_1 and another one for IoDev_4017_2 ,address are Ai0 -Ai7 for Each ADAM you have to select i/o device name separately for each variable.now you have 16 Analogue input 8 for IoDev_4017_1 from Ai0 - Ai7 and 8 for IoDev_4017_2 from Ai0 - Ai7 .
Old January 8th, 2011, 02:43 AM   #14
Vazgen
Finland
Vazgen is offline
hi sh984
thank you so much for your kind replay now i can run my project
every thing is ok
Old May 9th, 2011, 10:43 PM   #15
Vazgen
Finland
Vazgen is offline
Problem For Create 8 Digital Tag in Citect Ver 6.0
anyone can help me ?
how can i create 8 digital tag for ADAM -4068 ?i use of citect 6.0 and can't create digital tag more than 4.
pls help me ?
Do0
Do1
Do2
Do3
Do4...is not possible ..error message : Bad IO Device variable
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Citect Vs WinCC - Long Doug_Adam LIVE PLC Questions And Answers 22 October 3rd, 2014 12:56 PM
Citect SCADA Tag Import & Export kavee30 LIVE PLC Questions And Answers 13 February 23rd, 2013 12:05 PM
Citect SCADA trending problem ry_fern LIVE PLC Questions And Answers 2 February 17th, 2010 04:19 PM
Citect Variable tag problem brijacq LIVE PLC Questions And Answers 3 September 18th, 2006 01:27 AM
Citect SCADA Tag Export/ Import aju LIVE PLC Questions And Answers 1 January 19th, 2005 12:39 AM
