This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Dec 2004
time base control logic
S:4/1 what is this in control logic?
Thanks |
#2 |
Specify the system you are referring to. I suppose you are referring to a free running clock bit but different AB systems have a different time base.
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#3 |
Bernie,
I think when he said "control logic" he meant to say "ControlLogix" ... if so, the picture below might give some basic ideas ... note that since the ControlLogix "CurrentValue" increments in micro-seconds you'll have to play around to select a useful bit number ... (the bit "1" mentioned in the original question is probably going to be toggling WAY too fast) ... secret handshake: the S:4 "Free Running Clock" available in RSLogix500 isn't built-in with RSLogix5000 ... you have to use a GSV instruction to retrieve the data - store the data in an appropriate set of tags - and then you can use the data in your program ... if this "CurrentValue" data location doesn't meet your needs, give us more details about what you're trying to accomplish ... the GSV can access other data too ... and to be honest, if you just want to toggle a bit on and off, a "home brew" free running timer rung might be easier to set up in the long run ...
__________________
#4 |
In addition to using WALLCLOCK time as Ron mentioned, you can also create your own free running timer in RSLogix5000 by just creating an unconditional timer and using the .ACC bits of the timer. Never reset this timer, it will never reach its preset.
Unconditionally unlatch Free_Running_Clock.ACC.30 so that the timer will never time out. It will count to 1073741.824 seconds and then start over. Now you can access each bit in the ACC word, with each bit behaving similar to the S:4, except now you have 29 bits available for use instead of 16. The bit on time is 2Y milliseconds where Y is the bit number 0-29. The duty cycle is 2 times the bit on time, just like in S:4. Free_Running_Timer.ACC.0 = 1mS (2mS duty cycle) Free_Running_Timer.ACC.1 = 2mS Free_Running_Timer.ACC.2 = 4ms etc.
__________________
True craftsmanship is only one more power tool away. That's the beauty of processors, they don't have emotions they just run code - The PLC Kid. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Duty Standby Logic and controls for Chillers and Pumps. | abdulsattarmd | LIVE PLC Questions And Answers | 7 | September 12th, 2009 03:21 AM |
| Control Logix Controller Scan time | ss4884 | LIVE PLC Questions And Answers | 5 | April 9th, 2009 12:25 PM |
| AB Control Logic Motion Time Cam MATC Time Units | Peter Laing | LIVE PLC Questions And Answers | 3 | April 21st, 2007 05:31 AM |
| Error Control Logic through Indirect Addressing | JonSaundersTechEE | LIVE PLC Questions And Answers | 10 | January 4th, 2005 09:52 AM |
| frequency output | LIVE PLC Questions And Answers | 17 | August 13th, 2002 07:05 AM | |
