plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 15th, 2010, 01:09 PM   #1
jimdi4
United States
jimdi4 is offline
jimdi4's Avatar
Logix5000 AOI vs Data types?
Hello,
I was wondering if this was ever covered in previous threads:
I am new to AOI's (Add On Instructions) and to Data types. I usually just code straight forward logic.
I would like to use either an AOI or Data type to create control for a control valve, that will be standardized across many machines.
Can anyone give preference to either and AOI or Data type? Advantages? disadvantages? between the two...that would be great...
Jim
Old June 15th, 2010, 01:59 PM   #2
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
You are actually talking about two different but similar things.
The concept for the UDT and the AOI is similar. In each case you are building a template. In the case of the UDT - for a new composite data type. In the case of an AOI - for a logic procedure.
Ine each case, to actually use the template you have created you make a new tag (UDT) of you new type or create a new instance of the AOI which gets its own memory space and local tags.
So it's not so much a 'preference' as which do you use for a given purpose.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old June 15th, 2010, 03:22 PM   #3
jimdi4
United States
jimdi4 is offline
jimdi4's Avatar
Thanks Bernie....I have a similar question on two seperate COntrologix open sessions.
One session I copied an ACD from our server that contained the Add On Instruction, and I have another Contrologix session open that doesn't have an add on instruction in the controller organizer.
Is there something I have to flip on to view the add on instruction in the controller organizer if its not there?
I guess another way of putting it, I want to copy the AOI from one Contrologix program to another...I see where you can export the instruction as an *.L5X but how do I then import it to another program?
Old June 15th, 2010, 06:02 PM   #4
bernie_carlton
United States
First make sure your RSLogix5000 is at least version 16.
__________________
www.thePLCguy.com
Old June 16th, 2010, 12:54 PM   #5
jimdi4
United States
jimdi4 is offline
jimdi4's Avatar
Both are ver 17 and I figured it out in the help directory
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Logix5000 Data shifting Question koti LIVE PLC Questions And Answers 7 November 17th, 2009 01:34 PM
Vijeo Citect - Modicon M340 DDT (Derived Data Types) majorv LIVE PLC Questions And Answers 2 April 29th, 2009 06:34 PM
FiFo data types coopdegrace LIVE PLC Questions And Answers 1 March 18th, 2009 04:21 AM
S7 Data types coopdegrace LIVE PLC Questions And Answers 3 March 9th, 2009 04:37 AM
S7 compare different data types 314cpu Ned_Flanders LIVE PLC Questions And Answers 3 February 24th, 2009 10:51 AM
