plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 24th, 2010, 03:22 AM   #1
omsumitam
India
omsumitam is offline
omsumitam's Avatar
Interposing relays
What is the use of Interposing relay,
Is it only required for solenoid Valves because of different requirement Voltage (PLC is restricted to 0.5A at 220 VAC, but the solenoid which is to be connected to the relay requires 1.2A at 220 VAC.)
Can/Why we use it for Analog Signals .
How it works in the whole operation , in brief ? .I know its very basic. If any one can help me out of this .
Thanks in advance !!
__________________
Sumit Pandey
Quote:
There never was a good knife made of bad steel."
Old June 24th, 2010, 05:14 AM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
Relays can handle:
1) Voltage differences
2) Isolation
3) Switching analog signals (How does a PLC switch analog signals?)
4) Driving more current
5) Acting as inexpensive sacrificial elements.
6) Switch multiple loads at one time.
7) (optionally) Being a manual override.
8) Accommodate larger wire's then typical PLC modules.
You're right. Basic question.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old June 24th, 2010, 05:36 AM   #3
Jeev
Australia
Jeev is offline
Jeev's Avatar
You're forgetting relay logic. Although these days I only ever use relay logic to punish my apprentices and for my own sick amusement...
Old June 24th, 2010, 05:44 AM   #4
omsumitam
India
omsumitam's Avatar
Thanks .
so can a general system be described in the following way leaving apart are the Data highway, redundancy, etc.
i am here concerned about the Blue lines i.e., after Relays
__________________
Sumit Pandey
Old June 24th, 2010, 06:13 AM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
I have no idea what your are "Concerned" about. A relay is an electromechanical switch. That's all.
@Jeev - Thanks, you know, it's been so long myself I didn't think of that, but it's a valid use. Logic circuitry.
__________________
Old June 24th, 2010, 06:22 AM   #6
omsumitam
India
omsumitam's Avatar
Mr. rdrast
Your Answer is right but problem is with your attitude.
What you r telling , can be easily searched on google, so keep that information with you. we r here to share and solve the probs of self and other and increase the knowledge ,
if u r not concerned about that .
SHUT UP.
__________________
Sumit Pandey
Old June 24th, 2010, 06:28 AM   #7
Jeev
Australia
Jeev is offline
Jeev's Avatar
Quote:
Just recently I saw a simple machine out in the field that was controlled entirely by 2 VFD's, some sensors with delay timers built into them and a handful of relays. Needless to say the hobbyist and tinkerer in me was highly amused.... The Engineer in me was appalled, hahaha.
omsumitam - You're still going to need something to drive your Analogue Field Devices properly.
Old June 24th, 2010, 07:30 AM   #8
rdrast
United States
rdrast is offline
rdrast's Avatar
Quote:
Originally Posted by omsumitam View Post
Mr. rdrast
SHUT UP.
Ask a real question then. I'm not going to give you an introduction to electronics and controls. See ya... Ignore on.
__________________
Old June 24th, 2010, 10:07 AM   #9
harryting
United States
harryting is offline
harryting's Avatar
I only see one dude with the crappy attitude and it ain't rdrast.
Old June 24th, 2010, 10:21 AM   #10
Jeev
Australia
Jeev is offline
Jeev's Avatar
Mr. rdrast
SHUT UP.
No need to be rude. To address your concern about the blue lines:
1) The Relay's will switch your signals on and off.
2) You will need an Analogue Output Module on your PLC to control your field devices (And motors if they require Analogue control) through the switching relays.
3) You will need a Digital Output Module on your PLC to switch your relays.
4) Your relays might isolate your Digital control, but they will not isolate your Analogue control between the 2 systems, so make sure your earthing, Shielding and COMM/Analogue Refernce is wired correctly.
Don't let the pixels make you angry.
Old June 24th, 2010, 10:25 AM   #11
ydtech
Brazil
ydtech is offline
ydtech's Avatar
Sumit: rdrast's answer was right on the money. Google on relay usage, and take your pick of applications. Better yet, ask your teacher. In short, relays can be used to amplify the DO's capacity, isolate it from the field wiring, and so on.
Only time I've seen them used for analog signals was when they wanted to add some readings without spending on an extra analog card, the rack was full anyway. Having DOs available we scrounged up a handful of relays and cooked up a kind of slowpoke multiplexing sample and hold using one AI.
Oh, google on the meaning of 'interpose', in case that's your doubt.
Old June 24th, 2010, 10:36 AM   #12
Jeev
Australia
Jeev is offline
Jeev's Avatar
Quote:
It's actually not that uncommon... I've seen many cases where low sample rates were acceptable and this method was used to keep the system simple and cost effective. Not to mention many Microcontrollers will internally multiplex ADC channels to increase the number available to the user without incurring all the overheads of the individual channels. I'd almost put money on it that some Analogue Input cards do this too...
Old June 24th, 2010, 11:36 AM   #13
TheStarr
United States
TheStarr is offline
TheStarr's Avatar
rdrast posts = 2753
omsumitam posts = 22
I think omsumitam needs to find somwhere else to play while the real men around here get some work done.
P.S. rdrast, I always enjoy reading your input. Thanks for sharing your knowledge.
Old June 24th, 2010, 12:45 PM   #14
mordred
Canada
mordred is offline
mordred's Avatar
I concur RSDrast answer is right on the money and it was informative without insult
__________________
Can I ground short a Sparky?
Old June 25th, 2010, 06:49 AM   #15
tragically1969
United Kingdom
tragically1969 is offline
Mr. rdrast
SHUT UP.
Dude, you are the only one here i can see with the wrong attitude !
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Interposing Relays geniusintraining LIVE PLC Questions And Answers 3 June 28th, 2007 06:30 PM
Interposing Relays on output cards Erik vdH LIVE PLC Questions And Answers 30 June 28th, 2007 04:18 PM
Relays and Solenoids glaverty LIVE PLC Questions And Answers 10 November 10th, 2004 02:17 PM
Relays Instead of PLC in High Speed BarCode Application for Pharma??? jdcochran LIVE PLC Questions And Answers 6 September 29th, 2004 06:08 PM
Interposing Relay(s) okiebob LIVE PLC Questions And Answers 13 June 18th, 2003 03:05 AM
