This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
How to set 22-comm-e useing BOOTP
Hi to all. I have an Allen Bradley 22-comm-e adapter which I’m using with a PF 40, and I want to configure the settings. What communication cables do I need from the PC to adapter in order to configure, is it an Ethernet cable straight thru or X-over I’m using BOOTP.
Thanks |
#2 |
If connecting directly then use a cross-over just to be sure. Though I'm pretty sure the port on the 22-COMM-E can take a straight through (Automatic MDI/MDI-X).
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#3 |
![]() Join Date: Dec 2009
you will have to set your port to the network in the control panel setting (tcp/ip) and your network setting to the same address on your network settings on your BOOTP sever software
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| PID Control Versus PLC | DjFab | LIVE PLC Questions And Answers | 11 | May 12th, 2007 10:11 AM |
| Mitsubishi Q Series Modbus TCP module QJ71MT91 set up help req'd... | Pocko | LIVE PLC Questions And Answers | 0 | July 30th, 2006 02:45 AM |
| sew movidrive and ipos plus programming | liew_sc | LIVE PLC Questions And Answers | 18 | March 13th, 2006 03:10 AM |
| toggle logic in 'c' language | naishadgosai | LIVE PLC Questions And Answers | 11 | August 6th, 2005 08:53 PM |
| ab 5/25 set up | zxninja | LIVE PLC Questions And Answers | 8 | May 17th, 2003 03:36 AM |
