This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jun 2010
PanelView 1250 Screen saver
Ive just finished setting up a new panelview for a client. They would like to be able to reactivate the screen after the screen saver comes on via a remote input through the slc500. This is so they can view the screen through a window in a classified environment. As of now they are using a long stick to poke the screen through the window. I need to find a solution quick before i am replacing an impaled panelview. FactoryTalk View Studio is not my first language even though I am getting the hang of it.
Thanks, Pete |
#2 |
The screen saver on a PanelView Plus is actually a Windows CE function. When you set it up through the terminal's configuration menu, you're essentially just poking information into the Registry on the terminal.
There's no method that I am aware of to de-activate the screen saver via a controller. You can do that with RSView32 or FTView SE by using the AppActivate command and the Event Detector to kill the screen saver process, but not with the PV+ terminal running FactoryTalk View ME. What I've done instead is to use the Remote Global Connections feature to control the backlight brightness. This is described in RA Knowledgebase document 63659. This value is retained through power cycle, so don't set the brightness to zero or you won't see anything if you power cycle and disconnect the terminal. |
#3 |
![]() Join Date: Mar 2006
why dont you put the panelview on a digital output and turn it on via timer for a predetermined amount of time when they push the button?
if that isnt good enough why dont you just disable the screensaver? |
#4 |
Ken,
Thanks for the brightness idea. I knew you could control that but never thought of using that instead on the screen saver. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Panelview Plus 1250 "no touch" hand picture on screen | tomalbright | LIVE PLC Questions And Answers | 2 | March 14th, 2010 05:24 AM |
| Customized screen saver on PanelView? Possible? | ckchew666 | LIVE PLC Questions And Answers | 10 | July 21st, 2006 01:20 AM |
| Panelview Inactivity Screen Control | fartinmartin911 | LIVE PLC Questions And Answers | 2 | February 1st, 2005 12:57 PM |
| PanelView Screen Saver Mode | RKovacic | LIVE PLC Questions And Answers | 5 | July 16th, 2003 01:25 PM |
| PanelView 550 screen saver | solder jockey | LIVE PLC Questions And Answers | 2 | November 20th, 2002 11:45 PM |
