plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 23rd, 2010, 11:04 PM   #1
natcheappan
India
natcheappan is offline
Reg: RSLinx
Hi Everybody,
i had RSlinx version 2.2 and now i tried to install RSlinx version 2.41 without uninstalling the older version. the system gave a message "a older version of RSlinx is already present".
so i tried to unistall RSLinx 2.2, the system done the uninstallation and gave a message: "uninstallation completed successfully, but you have to remove few components manually".
what were the files and locations i have to remove?
can anybody suggest a solution for this, because without removing it the system didnt accept installation of RSLinx 2.41.
regards
N.Natcheappan
Old July 24th, 2010, 04:48 AM   #2
BobB
Australia
BobB is offline
BobB's Avatar
I cannot help you with RSLinx but this is one of my great annoyances with industrial software. The darned installation program should take care of this automatically!
Although AB software leaves things running and this may contribute to your problem. I run AB software in a virtual box - shut down the VB and shut down AB software.
The other annoyance with industrial software is most (all?) brands leave the registery full of garbage. I always run Registery Mecahanic to clean the registery out when either installing or uninstalling industrial software.
__________________
The Old Pfhaart
Old July 24th, 2010, 06:32 AM   #3
chavak
Malaysia
chavak is offline
chavak's Avatar
This topic is discussed many times here, please do a search on uninstall RSLinx, I'm sure you get a lot of response
Anyway here is the search link, just filter out those relevant. BTW I would download a newer version if wanted to upgrade, I guess it is at Ver 2.58 something, and the lite version is free
http://www.plctalk.net/qanda/search....archid=1887406
Old July 24th, 2010, 01:54 PM   #4
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
If you did not shut down RSLinx before you tried the uninstall you may still see the RSLinx icon on the task bar beside the clock at bottom right.
If by a remote chance it is there, right click on it to stop it, then try reloading the software,
Another remote option is go to control panel, then to add remove programs, and see if RSLinx is in the list of programs, if it is do an uninstall from there.
I know I may be grasping at straws, good luck.
Old July 26th, 2010, 08:57 PM   #5
natcheappan
India
Hi Everybody,
Thanks for your responses.
i got this problem solved.
when anyboy face a similar situation, just go to the registry editor and delete all entries marked with RSLINX.
do these steps...
start - run - type regedit - search for RSLinx - delete one by one all the entries marked with RSlinx.
after finishing this we can install the new version of RSLinx. now you wont face any issues.
thanks
Nachi
Old July 27th, 2010, 12:12 AM   #6
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
Brave man
Registry files make me Ahhhh Ummm scared
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wonderware Intouch with RSLinx Gateway without OPCLink. makarandsn LIVE PLC Questions And Answers 18 November 15th, 2011 06:18 PM
RSlinx 2.53 with Vista support available Contr_Conn LIVE PLC Questions And Answers 7 September 4th, 2008 07:56 AM
RSLinx upgrade question Spartan10 LIVE PLC Questions And Answers 2 June 19th, 2008 08:03 AM
RSLinx problem registering definitions from PIUNSOL.INI Koos LIVE PLC Questions And Answers 0 January 13th, 2008 10:23 PM
PV 600 Plus - Cockpit Trouble glaw LIVE PLC Questions And Answers 24 June 30th, 2006 10:53 AM
