plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 24th, 2010, 05:47 PM   #1
lonegator
United States
lonegator is offline
ERROR - Address must be specified to the bit level
I must admit that it's been awhile since I've written a PLC program so please excuse my ignorance. I am using RSLogix 500 with a SLC. I'm creating a data file for cross-referencing my analog inputs. I thought that I had to use an integer data file for doing this AND that the addresses must be specified to the word level. Because I don't have actual input and output locations yet, I'm just pointing the integer inputs to themselves. An example would be:
---][N30:3------------------------------------------------()N30:3
This is causing the error specified in the title. What am I doing wrong? I'm sure it's something simple. Thanks for your help!
Old August 24th, 2010, 06:00 PM   #2
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
You have only specified the address to the word level. N30:3 is the fourth word of the integer file N30. N30:0 is the first, N30:1 is the second, etc.
The contact insruction (XIC) and the coil instruction (OTE) can only be on or off. Consequently they must be referenced to a single bit. You need to append the bit number to the word address like N30:3/00 which would be the first bit of the fourth word on the integer file N30. Adresses at the bit level of N30:3 will range from N30:3/00 through N30:3/15.
Old August 24th, 2010, 06:02 PM   #3
harryting
United States
harryting is offline
harryting's Avatar
N30:3 is an integer, N30:3/X where X = 0 to 15 is a bit. A integer in RSLogix500 is made up of 16 bits. You need to specify to the bit level for the type of instruction you are using above.
Old August 24th, 2010, 06:02 PM   #4
sthompson
Canada
sthompson is offline
sthompson's Avatar
The instructions you are specifying are Bit Level Instructions, addressed to a Single Binary Bit, with a State of Zero or One. The address you are specifying to go with them is a Word Address which can be either -32768 to 32767 or 0 to 65536. (Hope my memory is good) This is incompatible, and RSLogix is warning you this can't work.
I am not sure what you mean by Cross Referencing your Analog Inputs. Perhaps you can give us some details of what you are trying to do.
Stu....
__________________
There's never time to do it right, but there is always time to do it over!
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Old August 24th, 2010, 06:02 PM   #5
Mickey
United States
Mickey is offline
Mickey's Avatar
You are using a word address ( 16 bit word e.g. N30:3)
You have to use a bit address with those instructions e.g. N30:3/0 for your XIC
and N30:30/1 for your OTE.
See pdf below for a little info on data file addressing.
Edit: sthompson types faster then I do.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old August 24th, 2010, 06:05 PM   #6
sthompson
Canada
sthompson's Avatar
Wow! I actually typed faster than Mickey for a change.
Edit: I am sure between the two of us, he will have a better idea what is causing his problem.
Stu.....
__________________
Old August 24th, 2010, 06:08 PM   #7
Mickey
United States
Mickey is offline
Mickey's Avatar
Stu.....
I haven't had my beer yet, but I think its time for one.
__________________
Mickey
Old August 24th, 2010, 06:14 PM   #8
STL???
United Kingdom
STL??? is offline
Here's mine lol
Old August 24th, 2010, 06:15 PM   #9
sthompson
Canada
sthompson's Avatar
Well it only 82 and very sunny here, but I agree with you.
I am heading for the door now. Enjoy a cool one Micky, you've earned it.
Stu.....
__________________
Old August 24th, 2010, 06:27 PM   #10
lonegator
United States
Many of these integers are going to be capturing/displaying various drive speeds, pressure amounts, etc. If I address to the bit level, that data won't properly display, will it? Again, sorry for my ignorance.
Old August 24th, 2010, 06:33 PM   #11
lonegator
United States
I'm writing the program for a plant start up. Because I'm not onsite until next week and because they want a copy of the program NOW (of course), I'm trying to do what I can to "make up" the inputs/outputs that will be used. We're using an I/O scanner and some ASB module so I can't put in any actual addressing until I'm successfully communicating with the system (right??). I made four data files (DI, DO, AI, AO) for my data. Currently I'm just pointing a data point to itself (as I showed in my example). Once I have actual address locations from the scanner/ASB module set up, I was going to substitute in the cross reference data files I'm setting up now to save having to search thru the program to change everything. (Let me know if all that does/doesn't make sense).
Old August 24th, 2010, 06:35 PM   #12
sthompson
Canada
sthompson's Avatar
No, it won't display properly. You will want to use an Integer Word to capture/displaying the Data. i.e. N7:0.
Stu......
__________________
Old August 24th, 2010, 06:38 PM   #13
lonegator
United States
But that's how I'm doing it, I thought. I created a data file of N30 and have been addressing them as N30:1, N30:2, etc. It's giving me the error.
Old August 24th, 2010, 06:39 PM   #14
Steve Bailey
United States
Is there any particular reason why you want to use words in an integr file for bit-level instructions instead of the B3 file?
If you feel you must use bits from N30 words for bit-level instructions be careful not to use bits from words that are being used for numeric data.
Old August 24th, 2010, 06:42 PM   #15
lonegator
United States
I need words though for the data I'm trying to transfer/display.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSSQL: specifying trigger to bit level geoplc LIVE PLC Questions And Answers 5 March 15th, 2010 05:48 AM
fishenguy fishenguy LIVE PLC Questions And Answers 54 November 13th, 2007 08:33 PM
Rotary Index Table app. gpdc LIVE PLC Questions And Answers 1 September 20th, 2007 12:22 PM
Tidbits, finding the bit number or index Peter Nachtwey LIVE PLC Questions And Answers 10 February 9th, 2006 03:17 AM
Latch a Bit then Bit Shift Left jthornton LIVE PLC Questions And Answers 2 August 22nd, 2003 06:35 AM
