plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 9th, 2010, 04:55 PM   #1
Robodude
United States
Robodude is offline
Fanuc robot with a Quickpanel HMI
I have a Fanuc R-30iA robot controller. I am using a GE quick panel for a HMI / operators panel. How do I define the robot I/O I would like to read and write in the quick panel. It seems like you define the signals as variables in the quickpanel. To start simple, I would like to put a program start and program stop button on the screen that would turn green based on if the program is running or not. It seems like you would use color animation for this and declare a input as a variable. Is this correct and how do you tie the variable to the robot IO?
Old September 9th, 2010, 05:06 PM   #2
Mtech
United States
Mtech is offline
What type of plc are you using to communicate between robot controller and quick panel. Have you ready configured robot UOP setting?
Old September 9th, 2010, 05:11 PM   #3
Robodude
United States
Robodude is offline
I am hooking the GE quickpanel directly to the robot via ethernet. I am not using a plc. I have not configured UOP yet. Will this set the IO up to be read by the quickpanel?
Old September 9th, 2010, 05:23 PM   #4
Mtech
United States
Mtech is offline
Never seen a additional HMI connected this way. How would,never mind. I guess if there is a will there is a way. I will have to research this as well. Do you have manuals and fanuc tech support?
Old September 9th, 2010, 05:56 PM   #5
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
What communications protocol does the robot use? Is it among the selections available to you in the Quick Panel's list of PLC access drivers or OPC drivers?
Old September 9th, 2010, 06:02 PM   #6
Robodude
United States
Robodude is offline
The robot is set up with SNPX or SRTP. I do not have the quick panel hardware yet. I have the proficy software I am starting to program the HMI with. I will have the robot and the GE quick panel in 2 to 3 weeks.
Old September 9th, 2010, 06:03 PM   #7
Robodude
United States
Robodude is offline
I have a manual on the robot and quick panel unit. I do not have the robot yet so I don't have a F# for fanuc support.
Old September 10th, 2010, 09:21 AM   #8
RussB
United States
RussB is offline
RussB's Avatar
I never met a Robot who talked SNPx or SRTP, all that I have seen are setup for EGD (Ethernet Global Data) or Genius (GE Proprietary highs peed Serial). At least it is simple to change the QP's variables from one protocol to another so any development is not lost.
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old November 5th, 2012, 03:40 PM   #9
edpg1
Canada
edpg1 is offline
I know this thread is two years old.
I am attempting to duplicate this situation of using a Quickpanel View with an R-30iA.
How do I get the variables from the Quickpanel to manipulate I/O on the Fanuc robot via Ethernet. What protocol do I need to use for this to work properly.
Old November 5th, 2012, 04:07 PM   #10
RussB
United States
RussB is offline
RussB's Avatar
Did you read the old posts?
What Ethernet Protocol(s) are on the Robot that match what is in the QP View?
Look in the "PLC Access Driver" area under "View OPC Drivers" to find what is available on the HMI. I recommend staying away from the "Native" drivers.
__________________
Old November 5th, 2012, 04:23 PM   #11
Robodude
United States
Robodude is offline
I have hooked up a GE quickpanel to the R30iA controller a couple of years ago. The option in the robot you need is SNPX / HMI ConnectionYou will then be able to communicate with the quickpanel via ethernet. Do you have the GE proficy software to build your interface on the quickpanel?
Old November 5th, 2012, 04:37 PM   #12
edpg1
Canada
edpg1 is offline
It also doesn't help that I don't really know the Fanuc robots either.
Is there a way to check what options are installed?
And yes I have the software, Version 7.0.
Old November 5th, 2012, 04:48 PM   #13
Robodude
United States
Robodude is offline
If you do a controlled start and select s/w install, you can see what options you have loaded into your controller.
Old November 5th, 2012, 10:46 PM   #14
RussB
United States
RussB is offline
RussB's Avatar
Quote:
SNPX in the GEIP world is a serial protocol, not Ethernet.
__________________
Old November 6th, 2012, 07:32 AM   #15
edpg1
Canada
edpg1 is offline
Quote:
I agree, I don't see any ethernet options for this protocol.
I do have the options installed, but what protocol do I use to communicate between the two?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fanuc robot mastering problem russrmartin LIVE PLC Questions And Answers 14 June 14th, 2012 09:50 AM
Fanuc Robot R-J2 M410iW PalletTool CPU Recovery OkiePC LIVE PLC Questions And Answers 5 November 29th, 2007 06:51 PM
Fanuc Robot, Devicenet, Turck - TRYING to make it all one happy family produktion LIVE PLC Questions And Answers 9 March 9th, 2007 07:53 AM
quickpanel to fanuc robot Scueter LIVE PLC Questions And Answers 2 February 10th, 2007 08:09 PM
Quickpanel to Fanuc robot Scueter LIVE PLC Questions And Answers 0 February 4th, 2007 01:11 AM
