Need Help for ControlLogix System
gherz817
Oct 2005
PHILIPPINES
58
Need help for ControlLogix System.
The system has 1 redundant Controllogix PLC connected to 3 ControlNet FO ring networks, HMI server and View Clients. Each FO Ring have 8 ControlLogix controllers. The redundant Controllogix is connected to the Ethernet switch including the HMI Server and view clients, and also connected to the 3 FO ControlNet rings via CNB/A module. The Operator Workstations (clients) will
Monitor and Control all the equipment in the plant. My question are:
1. Do I need to use the Redundant Controllogix as a Data Concentrator for all the Controllogix PLCs in the network? Or just Map all PLC controllers in the RSLinx and relay to the Operation Workstations?
2. What messaging should I use in this kind of setup if I will use the redundant PLC as a Data Concentrator? Produce/Consume or MSG instruction?
Thank you in advance for your inputs..
God Bless.
Hello automation experts, I'm trying to learn about servo axis control in AB ControlLogix PLCs (L33ERMS). Attached is an example of a servo...
1,074
My company has a workcell that has 1756-l61 plc , controllogix with multiple communications running, Ethernet, controlnet, devicenet, dh-rio...
2,090
Good day, I need help regarding how to communicate a DCS that uses controlnet for their HMI interface and I/O communications. Can the controlnet...
2,437
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
248
156
