This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Guest
Posts: n/a
analog inputs ??
hey folks ...
i have a question regarding analog inputs in s7 200 plc's what does A+ / A- / AR means ...and how can i connect them to the sensor i mean what kind of sensor ... i herd that there 2 wire type and three wire type ?? is that correct... and please give enough details about HOW TO CONNECT the sensor to the A+,A-,AR, inputs. thanks in advance... kumar. |
#2 |
Kumar,
the meaning of those connections is:
The how to connect part is to be found in the "S7-200 Programmable Controller - System Manual" in chapters A.28 "Expansion Module EM231 Analog Input AI 3 x 12 Bits" and A.29 "Expansion Module EM235 Analog Combination AI 3 / AQ 1 x 12 Bits". Kind regards,
__________________
Jean Pierre Vandecandelaere Trainer nautical sector VDAB Competentiecentrum L. Blondeellaan 9 B-8380 Zeebrugge Belgium |
#3 |
Guest
Posts: n/a
hi jvdcande,
thank you for the reply ... i have the manual that came along with the micro win document cd but the part which i dont understands ...which of these A+ A- AR give the PLC analog input the 0 to 10v signal,do you mean that the A+ , A- are the power supply from the plc to the sensor ,and the AR is the sigle returned from the sensor to the plc input ? can you please explain more jean ..... thank you in advance. bebst regards .kumar.
#4 | |
Quote:
If you are using a current sensor, you have to connect the positive side of the sensor to both the resistor and the positive input of the module (shown are RC and C+) while the negative side of the sensor is to be connected to the negative input (here C-). In this way you generate a voltage across the resistor (current-to-voltage converter). If you don't use a certain input you have to short the positive and the negative inputs (here B+ and B-) to avoid noise readings. The internals of the module are shown in the fourth figure of that chapter (in my case figure A-30), which should clarify everything. The power supply of the sensors is not shown on these figures and has little or nothing to do with the PLC itself. Kind regards,
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens CPU313C Analog Inputs | sherman4 | LIVE PLC Questions And Answers | 2 | February 25th, 2005 03:02 AM |
| S7 300 SM331 Analog Inputs Problem; Relative DC leval of adjacent inputs. | David Torrens | LIVE PLC Questions And Answers | 4 | November 10th, 2004 10:14 AM |
| Analog Inputs | asha6965 | LIVE PLC Questions And Answers | 4 | August 17th, 2004 03:32 PM |
| Siemens Analog Inputs | KA24DE | LIVE PLC Questions And Answers | 5 | February 4th, 2004 05:05 AM |
