plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 19th, 2003, 09:33 AM   #1
gbradley
United States
gbradley is offline
gbradley's Avatar
DoubleSolenoid
Not really PLC related.\
I have an german press that we just received.
On the Air clutch, the Valve has two solenoids.
any Idea what this is for?
Old November 19th, 2003, 09:34 AM   #2
gbradley
United States
gbradley is offline
gbradley's Avatar
Here is the back side of the valve
Old November 19th, 2003, 10:07 AM   #3
randylud
United States
randylud is offline
randylud's Avatar
Maybe
This could be a double acting sol valve. This is usually where there is not a NO or NC position, but you have to shift the spool in the two directions by energizing the coil for that position. Then again, if I could read German, the lable might tell just what the heck the thing is.
p.s. George, I looked a second time at your pics and I do not see a spring mechanism for shifting the spool when the coil de-energizes, so I may be on to something here with the double coils.
__________________
Thunder is good, thunder is impressive; but it is lightning that does the work!
Mark Twain-8/28/1908
Old November 19th, 2003, 04:51 PM   #4
Kidblue
England
Kidblue is offline
Kidblue's Avatar
Have worked with lots of German Press equipment, and normally a Dual Solenoid valve is used as a safety valve. Both spools need to move simultaneously. If there is a slight delay between them (ie one starts to stick), then a microswitch is activated (pneumatically within the valve), which in turn should 'Lock' the valve out and flag up an alarm. The valve should not be able to re-energise until the switch has been reset.
Hope this helps.
Old November 19th, 2003, 04:55 PM   #5
gbradley
United States
gbradley is offline
gbradley's Avatar
Thanks Kid. I think that you are right on.
This press must have been in some sort of test lab??
All of the contactors for the motors were in another room.
lots of wiring!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
