plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 19th, 2003, 10:53 PM   #1
ramcr
India
ramcr is offline
ramcr's Avatar
Thumbs up reduction of outputs
any experienced people please explain the circuit for reducing the outputs used in PLC . for example a single output should be used to energise two lamps which indicates complementary function
Old November 19th, 2003, 11:05 PM   #2
Sleepy Wombat
Australia
Sleepy Wombat is offline
Sleepy Wombat's Avatar
Have the output energise an external relay with a change over contact.
Old November 20th, 2003, 12:44 AM   #3
ramcr
India
ramcr is offline
ramcr's Avatar
Thanks for your reply sir but the output circuit i asked is without using a relay.
__________________
ram
Old November 20th, 2003, 12:49 AM   #4
Eric Nelson
United States
Eric Nelson is online now
Eric Nelson's Avatar
See my answer to JD's "10 outputs from 7" challenge in THIS POST. That should give you an idea about how you can get by with minimal outputs.
And it uses none of those 'annoying' relays!...
beerchug
-Eric
Old November 20th, 2003, 12:09 PM   #5
Antipathy
England
Antipathy is offline
Antipathy's Avatar
Eric
I just looked at your post on the JD thread and I'm not sure it works!
How, for example, could you have lamps 1 & 4 on without lamps 2 & 3 also being on?
As far as I can see it would only work if exclusive (only one at a time) lamps were required; in which case you could extend the logic to make 12 from 7 (3 x 4) or 16 from 8 (4 x 4).
Anthony
Old November 20th, 2003, 06:13 PM   #6
Eric Nelson
United States
Quote:
That's correct!...
If you notice, JD's 'challenge' was "10 individual lights with 7 outputs".
I just thought ramcr might glean some knowledge by looking at it...
beerchug
-Eric
Old November 20th, 2003, 06:48 PM   #7
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
Did I read this wrong? Is there more to it then what I see stated?
If by complemetary you mean 2 devices work at same time?, then the answer is obvious...wire them parallel. This assumes the plc output is capable of the power needed to drive the 2 devices.
There are creative ways using relays to make different multiple devices work from different outputs...but WHY do it? Just add more I/O or a larger plc.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old November 20th, 2003, 06:57 PM   #8
Eric Nelson
United States
Complementary: Of words so related that each is the negation of the other; "`male' and `female' are complementary terms"
I think this is the definition ramcr meant. IOW, one lamp to indicate the output is ON, and the other to indicate the output is OFF. Most, if not all of us, would use a SPDT relay to do this, but ramcr has some 'no relays' rule to follow...
beerchug
-Eric
Old November 20th, 2003, 07:13 PM   #9
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
I see what you mean but the statement doesnt follow that logic..I think he meant it in another fashion which may also apply...ie Supplying mutual needs or offsetting mutual lacks.
If that is the case then what I stated should be correct, his statement was:
I am getting better at reading the details.
__________________
Old November 20th, 2003, 07:16 PM   #10
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
I would look for a contact output module with form C contacts.
Old November 21st, 2003, 01:37 PM   #11
Antipathy
England
Antipathy's Avatar
Eric said:
I really need to read things more carefully...
Ron said:
Some of us don't always have the luxury of this option!
The reason I got excited when I first saw Erics post is that I am frequently burdened with the problem of customers wanting extras on the agency machines we sell. These machines are low budget imports usually with just enough I/O for their standard operation and no room for expansion. In fact usually basic non-expandible PLC's are used!
Anthony
__________________
-Anthony
Old November 23rd, 2003, 08:40 AM   #12
jvdcande
Belgium
jvdcande is offline
jvdcande's Avatar
Anthony,
that's what you get when customers want extra's on low budget machines: problems. In my experience it's the one or the other: low budget or extra's, never both.
ramcr,
from your post I think you're looking for a circuit where two lightbulbs are connected in series between the power rails with the center connected to the PLC output. Unfortunately, most PLC's have open collector outputs, so you can't use this solution.
I have seen this circuit a lot in the old days when we were using discrete logic (eg. 7400 family) where some functions had totempole outputs. In that case this is indeed a simple way to indicate both the ON and the OFF-states.
Kind regards,
__________________
Jean Pierre Vandecandelaere
Trainer nautical sector
VDAB Competentiecentrum
L. Blondeellaan 9
B-8380 Zeebrugge
Belgium
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
120Vac outputs Tim LIVE PLC Questions And Answers 18 December 19th, 2004 05:11 PM
AB 1794-ADN 'outputs in fault'<?> jdbrandt LIVE PLC Questions And Answers 2 December 10th, 2004 09:40 AM
Reliability of plc relay outputs Goody LIVE PLC Questions And Answers 1 January 27th, 2004 11:41 PM
Outputs gbradley LIVE PLC Questions And Answers 3 January 30th, 2003 12:01 AM
AB PLC5 Outputs turning themselves off! TCIG LIVE PLC Questions And Answers 9 August 19th, 2002 07:48 AM
