plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 10th, 2010, 10:10 PM   #1
avalancheroy33
United States
avalancheroy33 is offline
Adding a TON with TwinCAT
I just took over aproject and need to add a timer using twincat software, but do not have much experience with it. I know how to map in inputs and outputs, but dont know how to add a timer. need to get equipment back online to night hopefully -- any help is much appreciated.
Old November 11th, 2010, 01:38 AM   #2
L D[AR2,P#0.0]
Supporting Member
United Kingdom
L D[AR2,P#0.0] is offline
In the sample project supplied with TwinCat (TwinCat\Samples\FirstSteps) there are examples of the use of TON
Old December 16th, 2010, 11:54 PM   #3
Andreik
Philippines
Andreik is offline
I was able to simulate and run TON using Structured Text. I have activated "T.IN", however deactivating "T.IN", I noticed that "T.Q" remains activated. When I set "T.Q:=FALSE", the program shows error message. How can I turn this "T.Q" OFF?
Example program:
dev_down := NOT dev_up;
IF start THEN
t1(IN:=TRUE , PT:=t#1s , Q=>, ET=> );
IF t1.Q THEN
dev_up:=TRUE;
t1.IN:=FALSE;
END_IF
END_IF
Thank you very much,
Andrei K.
Quote:
Old December 17th, 2010, 09:16 AM   #4
TurpoUrpo
Finland
TurpoUrpo is offline
You must always make the call of ton. Now if start is not true you wont call the ton.
Code:
IF start THEN
      t1(IN:=TRUE , PT:=t#1s , Q=>, ET=> ); //this one will execute the ton, if start is not true, it wont execute, also when call is made u assign true to in so it will always be true when call is made.
  IF t1.Q THEN
    dev_up:=TRUE;
    t1.IN:=FALSE;
  END_IF
END_IF
Old December 20th, 2010, 03:21 AM   #5
Andreik
Philippines
Andreik is offline
Good day,
Thank you very much. I was able to put up a decent ST program just today and this will be the beginning of more complex programs to make. Here is my improved simple "TON" program:
IF NOT start THEN
t1(IN:=FALSE , PT:= , Q=> , ET=> );
t2(IN:=FALSE , PT:=, Q=> , ET=> );
dev_up:=FALSE;
END_IF
IF start AND NOT t2.IN THEN
t1(IN:=TRUE , PT:=t#1s , Q=>dev_up , ET=> );
END_IF
IF start AND dev_up THEN
t2(IN:=TRUE , PT:=t#1s, Q=> , ET=> );
IF t2.Q THEN
dev_up:=FALSE;
END_IF
END_IF
Quote:
Code:
IF start THEN
  IF t1.Q THEN
    dev_up:=TRUE;
    t1.IN:=FALSE;
  END_IF
END_IF
Old December 20th, 2010, 03:36 AM   #6
TurpoUrpo
Finland
You should call the timer exactly once in one program scan.
Example:
Code:
IF (StartCondition)
    THEN
    t1.in := true;
ELSE
    t1.in := false;
END_IF; //this could also be written "t1.in := StartCondition;"
t1(IN:= , PT:=t#1s , Q=> , ET=> ); //execute timer
IF (t1.q)
    THEN
    //do stuff
END_IF;
Basically, modify input parameters, then execute timer, then read output parameters.
Old December 20th, 2010, 07:08 PM   #7
Andreik
Philippines
Andreik is offline
Now that's way much convenient. Thank you very much as my ST programming has really improved in a few day span. Here is my revised program:
t2(IN:= , PT:=t#1s , Q=> , ET=> );
IF NOT start THEN
t1.IN:=0;
t2.IN:=0;
dev_up:=0;
END_IF
t1.IN:=1;
IF t1.Q THEN
dev_up:=1;
END_IF
END_IF
t1.IN:=0;
t2.IN:=1;
IF t2.Q THEN
t2.IN:=0;
dev_up:=0;
END_IF
END_IF
Example:
Code:
IF (StartCondition)
    THEN
    t1.in := true;
ELSE
    t1.in := false;
IF (t1.q)
    THEN
    //do stuff
END_IF;
Old May 7th, 2011, 12:12 AM   #8
fsoria
Philippines
fsoria is offline
don't assign value to Q...you should just monitor the value of Q so that you can control the IN
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Beckhoff - twincat problem (newbie) titi_nicolas LIVE PLC Questions And Answers 9 January 14th, 2011 10:02 AM
TwinCAT EtherCAT Help Needed sujal.sheth LIVE PLC Questions And Answers 11 March 29th, 2010 09:38 AM
TwinCAT remote OPC connection hatchor LIVE PLC Questions And Answers 2 April 15th, 2008 07:59 PM
ST program calling FB with a TON inside it - TON not working help pls matt_sd LIVE PLC Questions And Answers 3 November 5th, 2007 09:11 PM
CP5512 and TwinCat ? adcoPLC LIVE PLC Questions And Answers 2 March 14th, 2005 02:04 AM
