plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 6th, 2010, 12:22 PM   #1
Howard999
United States
Howard999 is offline
Ethernet connection on PC no longer working after using RSLinx to connect to PLC
My network connection on my lap top no longer works. It just says network cable unplugged. This same thing happened on another laptop, that the maintenance guys use for troubleshooting on the floor. Both are Panasonic toughbooks, both came up with the connection problem after installing RS5000 and using them on a Control Logix Processor. Has anyone seen this happen before and what is the fix? We typically set the IP address of the laptop when using the RS5000 software and use detect automatic for LAN use.
Old December 6th, 2010, 12:28 PM   #2
bkottaras
United States
bkottaras is offline
Do they use the same laptop for SLC500s??
Say ones with the funny looking RJ-45 port on the front?
Which is not Ethernet and can fry your ethernet port on your PC if you "Accidentally" plug it into on of the DH ports?
Old December 6th, 2010, 12:37 PM   #3
Howard999
United States
They do use the same laptop for SLC500, but they use the serial cable and DF1 driver. We did have an issue with another laptop and a AIC when they plugged the enet cable into it, it took out the adapter.
Old December 6th, 2010, 12:49 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
I have the same sinking feeling that your PC's Ethernet port got plugged into an old SLC-5/01-02-03 controller's DH485 port. These have +24V on one of the pins, which will destroy an Ethernet twisted-pair transceiver.
RSLinx uses the ordinary TCP/IP stack; it cannot affect the link detection or IP assignment functionality of your Ethernet NIC.
Old December 6th, 2010, 12:53 PM   #5
Howard999
United States
I cannot say for 100 % certainty on the maintenance laptop, but on my personnal laptop that has not happened. It was a new laptop with ethernet working. I installed the RS5000 software with RSlinx and went down to a machine to test connectivity. I changed my IP address to a static address and connected to one of our Control Logix processors via ethernet IP driver in RSLinx. Thought everything was fine until this morning when one of the other engineers up here ask if my laptop connection was working. So I turned it on and no good. I have uninstalled RSLinx and am in the process of reinstalling. I did a restore prior to reinstalling to hopefully set the laptop back to a good point.
Old December 6th, 2010, 01:14 PM   #6
Howard999
United States
I am sending these posts from another laptop that I use regularly to connect to both SLC500 and Control Logix platforms, I have not had any trouble with my ethernet port on this laptop, I am using an older version of RSLinx though.
Old December 6th, 2010, 01:23 PM   #7
Howard999
United States
I have reinstalled RSLinx but it is still giving the message that network cable unplugged. I check the network adapter in windows and it says the device is working properly. ????????
Old December 6th, 2010, 01:26 PM   #8
bkottaras
United States
Just because the port works fine doesn't mean that it will display "connected" when there's no physical cable attached to it.
Old December 6th, 2010, 01:27 PM   #9
Howard999
United States
Cable is attached and I checked the cable to another PC and it is good.
Old December 6th, 2010, 01:28 PM   #10
Howard999
United States
I should add that the cable is connected to our LAN.
Old December 6th, 2010, 01:28 PM   #11
bkottaras
United States
Maybe the "other" side has a problem with its port and not your PC.
Old December 6th, 2010, 01:35 PM   #12
Howard999
United States
I connected the ethernet cable to this laptop I am sending posts from and the connection is working to connect to ethernet.
Old December 6th, 2010, 01:38 PM   #13
bkottaras
United States
Try to connect to the internet the same way you connect with this PC.
If it works, then there's no issue with your cable, port and such.
If it doesn't, you may need to assign IPs and subnets and such (unless you get dynamic IPs from your IT set up).
Old December 6th, 2010, 01:39 PM   #14
Howard999
United States
already tried that, I have all settings the same.
Old December 6th, 2010, 01:41 PM   #15
bkottaras
United States
You looked into the ethernet adapter properties and you have a match?
And still won't connect?
Have you tried a ping?
A known IP which is currently active?
If you get a reply your port is working.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
how to connect Rslogix to logix5561 plc using ethernet jiten84 LIVE PLC Questions And Answers 2 March 24th, 2010 05:47 AM
Problem with connecting s7 319 PLC and PC station b00c LIVE PLC Questions And Answers 0 May 12th, 2009 11:17 AM
SLC504 Can't connect PC to RS232 but can connect through SIXNET Modem on RS232 port caseyswett LIVE PLC Questions And Answers 22 December 10th, 2008 12:41 PM
Mitsubishi MELSEC Q ethernet questions Picho LIVE PLC Questions And Answers 14 October 21st, 2005 08:09 PM
Simulator, Simulation, Shadow Code Terry Woods LIVE PLC Questions And Answers 1 January 2nd, 2005 01:40 PM
