This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jan 2011
Ethernet Best Practices
MY customer's plant has a Main PLC (SLC 5/05) which communicates with one CompactLogix and three other SLC 5/05's. There are Six (6) PC's with OPC servers communicating (Read/Write) with the main PLC. All of these devices share an ethernet newtork and it is VERY SLOW. The question is what is the best practice for a network such as this. Should we add another ethernet card to the Main PLC and have that communicate with the OPC servers? Should we use a different communications method for the PLC Only Network? The I/O count on the network is approximately 300 Digital I/O and 200 Analog I/O plus another 500 registers.
#2 |
Welcome to the forum.
I think you may need to provide more information to get good responses. What part(s) of the communication appear to be very slow? Are the inter-PLC communications done with multiple MSG instructions? Can you provide a sketch of how the network is laid out including switches/routers? Paul
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants. "You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway." |
#3 |
Ethernet should not be that slow, however, there are limitations on how many Ethernet connections the SLC5/05 will support. The SLC Communications are done by the PLC during the Housekeeping part of the cycle, so it is limited to how many messages it can process each cycle. Here is the Ethernet Manual;
http://literature.rockwellautomation...s001_-en-p.pdf Are your messages on some kind of Interval Timer? What is the update frequency of the OPC Servers? You may be able to use a SVC Instruction to help with the SLC response time, however, bear in mind that this doess affect your scan time. It is in Chapter 12 of the Instruction Reference Manual; http://literature.rockwellautomation...m001_-en-p.pdf There is also information on the Ethernet Communications in the Hardware Manual in Appendix G; http://literature.rockwellautomation...m011_-en-p.pdf Stu....
__________________
There's never time to do it right, but there is always time to do it over! No trees were killed in the creation of this message. However, many electrons were terribly inconvenienced.
#4 |
AS has already been posted too many message instructions will clog slc procesors on ethernet real fast.
What links the network? Make sure you have swithces and not hubs. Check the duplex and link speed of all devices as they need to be the same for the best performance. Make usre your devices are all set for 100 T and none are at 10T Check the ip addresses and subnet masks of all devices and make sure they are on the same logical ethernet network and not together in a SuperNet |
#5 |
![]() Join Date: Jul 2005
Another trick I've used in the past with SLCs - XOR the memory area you transfer to another PLC to see if any bits have changed. If changed, then send, otherwise there's no need to clog the processor.
#6 | |
Quote:
Kudos! ![]() ![]() ![]() Stu.....
__________________
#7 |
What kind of hub/switch are you using?
__________________
Nathan Boeger, CISSP-ISSAP, CCVP/CCNA, MCSE, VCP "Design Simplicity Cures Engineered Complexity" Sierra Nevada Brewery MES/ERP case study - 5 minute video, My comments Comment on Not another industrial software Blog Ignition by Inductive Automation, rethinking SCADA for modern manufacturing 2 minute video |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| UNIGATE CL Ethernet IP Connectivity Issue | Hal9000 | LIVE PLC Questions And Answers | 6 | January 11th, 2012 11:28 AM |
| New PC, Dual Ethernet Port Access to Rslinx | SNK | LIVE PLC Questions And Answers | 2 | February 4th, 2009 07:24 PM |
| S7-226 ethernet module errors!!! | Scott-bc | LIVE PLC Questions And Answers | 2 | November 28th, 2008 09:53 AM |
| Using a RADES9300 and serial ethernet to connect to plc...Works over eth but not dial | bdoub1eu | LIVE PLC Questions And Answers | 5 | July 28th, 2006 08:30 PM |
| AB Softlogix Version 13 and MSG over Ethernet | Roy C. | LIVE PLC Questions And Answers | 0 | October 19th, 2004 06:41 PM |
