plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 21st, 2011, 09:28 AM   #1
Ned_Flanders
England
Ned_Flanders is offline
Ned_Flanders's Avatar
S7 datablock data types
While attempting to add a couple of functions I have found a discrepancy between the data types in a datablock between the running program and the backup copy the manufacturer left.
Can I online edit the data types rather than change and download the whole block?
The datablock contains lots of machine setting values and I don't want thes to default to "Zero"!!!
Thanks, Mark
__________________
What do you mean "You're not in tomorrow?" D'oh!
Old February 21st, 2011, 09:52 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
No, you cannot change the declaration and keep the actual online values.
This is one of the most irritating deficiencies of STEP7.
I suggest that you change the data types in the offline project, but just make sure that the location of variables dont change.
Change from WORD to INT or DWORD to DINT or DWORD to REAL will be OK.
Then do not download this modified DB to the PLC.
You can then at a later time carefully update the offline DB's actual values with the online DBs actual values.
When everything lines up with the correct values and types, do a download to the PLC.
__________________
Jesper
See my profile interests for Q&A
Old February 21st, 2011, 10:43 AM   #3
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Quote:
Are the data types that are different the same length e.g. word/int or dword/dint ?
Old February 21st, 2011, 11:52 AM   #4
Ned_Flanders
England
Quote:
Unfortunately, No! Running copy is "INT" and backup "DINT". I can't really understand why they are different!
__________________
Old February 21st, 2011, 12:09 PM   #5
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Maybe several DINTs have been changed into double the number of INTs.
Is the size of the DB in bytes the same as before ?
Or are the modifications at the end of the DB ?
__________________
Jesper
Old February 21st, 2011, 01:19 PM   #6
Ned_Flanders
England
You are right - the block is the same size.
I can work around the problem - just dont want to loose 7 years worth of settings!!!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Simatic S7 - DataBlock data Lose !!! biomorf LIVE PLC Questions And Answers 4 February 5th, 2009 05:29 AM
Fetch data from S7 over TCP/IP namboothiripad.mbs LIVE PLC Questions And Answers 2 December 31st, 2008 11:51 AM
Filling block of data in S7 wasim LIVE PLC Questions And Answers 1 January 12th, 2008 06:53 PM
Move String Data in Ladder Logic S7 Siemens blacksilver80 LIVE PLC Questions And Answers 14 December 12th, 2007 02:28 PM
Searching for a S7 PLC analyzer (for collect and draw chronogram of data) Volkan LIVE PLC Questions And Answers 2 July 6th, 2002 09:36 AM
