This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jul 2004
It's a Saturday, and I had a couple minutes to kill so I made up my list, please add your own, I can't wait to see what you all come up with!
1. When you watch shows like “How It’s Made” you think to yourself “I could’ve done that way better”. 2. When watching the aforementioned TV program, you get excited to show someone else a piece of hardware you work with, and try in vain to explain while the DVR is running in slow motion. 3. You realize when you try to explain how you program a PLC to someone outside of your career field, they ultimately say “So you just say if this is on and that’s off, you turn this on?? Sounds pretty easy.” And you just get mad. 4. You want to know what servos the robots in iRobot were running on. 5. You fall asleep with a question about how to pull off a piece of programming in your head, and wake up in the middle of the night with the answer. 6. You’ve asked your boss for OT because while technically sleeping, your subconscious is doing work, therefore should be compensated accordingly. 7. If you aren’t working out programming while you sleep, your dreams are consumed by nightmares of someone removing the battery and then turning off the circuit breaker. 8. You think about all the ways your house would be tricked out if only your boss would let you have a PLC and a couple of I/O cards. 9. You see this size of a hard drive, and the size of the biggest program you’ve worked on, and you realize that computer software programmers must be really inefficient. 10.When you go into a new plant, and they ask you if you’re wearing bracelets, watches, or any loose fitting clothing, you look at him like he just asked you if you were on fire, because you haven’t been able to wear a watch in 7 years. |
#2 |
You use PLC to run your xmas lights
__________________
Life's to short and that just sucks! |
#3 |
At the top of the hill, you are more excited about the guy with the laptop in the j-box at the top, and how the motor is coupled to the chain, than the fact that your roller coaster is about to make a 70mph 110' drop.
__________________
A rebel who's taking a pause. It's not all the variables I am most concerned with, it's the undiscovered constants. "You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway." |
#4 |
![]() Join Date: Jun 2007
This one could be dangerous... When I start thinking very conciously about the control loop that is the eye/brain/foot thing that maintains a constant velocity on the road. Hey, I'll have to try an auto-tune next time I pull out
![]() Re "How it's made", I have to watch that with the sound off. I don't know about the US one but the producers of the UK version have used a machine that they don't show us that removed the brain of the presenter. He couldn't change a tyre. I'm sure the script writers have a few laughs at his expense, like the injection moulding m/c that's running at say, 2000 psi and they've converted it so that he says "...and the molten plastic is pushed into the mould with a force of nine hundred and seven kilograms per two point five centimetres squared." WTF? As for middle of the night stuff, well we all twitch a bit from time to time but when I spent two years working on a machine development for forming fine tubes into heat exchanger parts, my nocturnal psyche took on the actions of just about all the servo axes at once! That job nearly cost me more than I care to think about. How it all permeates into the family: Handing my daughter a cup of tea and she goes to take it with a smooth, controlled, perfectly horizontal outreach of an open hand (that made me smile) but then when she's a few inches away the hand/wrist/grip action totally screws up and she makes fizzing, graunching noises. She's heard too many tales of misguided servos. That one had me in tears. Well, thank you Dr. Kroger, see you tomorrow at eight... |
#5 |
__________________
True craftsmanship is only one more power tool away. That's the beauty of processors, they don't have emotions they just run code - The PLC Kid. |
#6 |
Brilliant... one of my very favorite XKCD comics.
#7 |
Your logged on to PLCS.net at 2:00AM
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#8 |
![]() Join Date: Jun 2010
Or even 12:30 am!!
#9 |
You go to work with an ear infection on one hours' sleep so you can get a rare opportunity to modify a PLC-5.
You then come home, sleep ten hours, and jump on PLCTalk.net before going to work at 5 am on Sunday.
__________________
#10 |
Never sleeps.......
__________________
___________________________ ControlLogix & SLC Trainingabtrain@tiscali.co.uk www.abtrain.co.uk tel: 07506 73 9999 self-help and help-yourself often get confused - ancient daba proverb |
#11 |
Daba, by my estimation it was well after midnight in the UK when you made that last post.
__________________
#12 |
its 00:25 now - our clocks just changed for DST otherwise it would have been 23:30
i suspect your calculation needs refining, lol
__________________
#13 |
Shouldn't the sheep have gone into error mode?
__________________
#14 |
If you use a PLC forum more that just troubleshooting or asking for help.
I think of this as a PLC geek facebook. You can see who is doing what or what area the other guy is strong in. I have made more than a few friends on here. So I fall into this category.
__________________
There should be a minimum IQ before people can breed |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Slightly OT: Siemens Masterdrive OPS1 navigation and Fault Logs | Ken Roach | LIVE PLC Questions And Answers | 11 | December 15th, 2009 01:42 PM |
| Siemens or Omron? | Gromit | LIVE PLC Questions And Answers | 30 | September 13th, 2008 11:22 AM |
| Date and time manipulation in STEP7 | Pandiani | LIVE PLC Questions And Answers | 3 | April 19th, 2006 01:34 PM |
| OT - Multiplication and PLCs | RMA | LIVE PLC Questions And Answers | 4 | September 6th, 2005 06:33 AM |
| Modicon 984 PLC Time settings | ControlLogix | LIVE PLC Questions And Answers | 20 | July 10th, 2004 11:39 AM |
