plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 27th, 2011, 07:10 PM   #1
brendan.buchan
Australia
brendan.buchan is offline
AutoCAD for electrical schematics
Hey,
Recently our small company has decided to start using AutoCAD for all of our electrical schematics, as this seems to be the industry standard.
Previously we were using Microsoft Visio, which although not as powerful, was very easy to use.
The problem I am having though is trying to find a suitable title block and electrical symbols to use.
Unfortunately whenever I try to search for electrical symbols/title blocks for AutoCAD it only brings up information regarding "AutoCAD Electrical"
Does anyone have any idea if there are any free IEC electrical symbols and electrical title blocks available for normal AutoCAD?
I have already got the JIC symbol package from MrPLC forums, but this won't be suitable for the majority of our work.
Any information on the best way to start using AutoCAD for electrical schematics would be appreciated.
Cheers.
Old March 27th, 2011, 09:53 PM   #2
Tharon
United States
Tharon is offline
Well, the best way would be to get the Electrical package for AutoCAD. It has some pretty nice features. We just started using it too. It takes some time to setup initially. Putting all your standard devices in, manufacturers, part numbers, etc. But it saves this all, and once everything is setup, it's nice.
Old March 28th, 2011, 02:53 AM   #3
brendan.buchan
Australia
You mean AutoCAD Electrical right? Which is a whole new package?
We already have a copy of vanilla AutoCAD 2010. I was hoping just to use this for basic electrical schematics.
AutoCAD Electrical seems a bit overkill for what we need.
No one uses normal AutoCAD for electrical schematics?
Old March 28th, 2011, 05:33 AM   #4
ianingram
Australia
ianingram is offline
Quote:
and
Hi Brendan,
It depends on what you are doing...
I also work for a small company. Sometime ago, my boss trialled/investigated different CAD packages for our schematics/panels.
We found that AutoCAD Electrical to be too expensive, EPLAN to be too hard/complex to learn, and then we found Promis-e.
Now, I am not about to recommend/not recommend this product for you , as I don't (fully) know your needs.
For example;
How many hours a week are you doing drawings?
Do you need to produce drawings with coil/contact cross referencing?
Do you need terminal/termination diagrams
Do you need cable schedules (automatically generated from drawings)?
Do you need automatic wire numbering? Then the ability to export your wire numbers to other packages (such as printers)?
You can read more about Promis-e Versus AutoCAD electrical here in a previous thread.
If you wish to use the AutoCAD LT that you have, then you may be best developing your own symbols & title block(s). Do you use similar parts regularly in your projects?
If your are using AB gear, there are symbols available on their website, but they may not easily fit into your drawings.
Hope this helps
Ian
Old March 28th, 2011, 07:18 AM   #5
James Mcquade
United States
James Mcquade is offline
That's what i have been using for years.
I have had to build our symbols library and it has grown.
Electrical, pneumatic, hydraulic, mechanical components,
and the list goes on. we add to it everytime we have a new component.
regards,
james.
Old March 28th, 2011, 07:36 AM   #6
glenncovington
United States
glenncovington is offline
glenncovington's Avatar
You might try to search here:
http://cben.net/?query=electrical
Old March 28th, 2011, 06:59 PM   #7
brendan.buchan
Australia
Thanks for the info.
We really don't do many drawings.
We are primarily industrial service electricians that focus on maintenance/breakdowns.
I myself do mostly programming although a lot of it is modifying existing systems, rarely anything new from the ground up.
Every now and then we might overhaul a machine or re-do a safety system though which is where we will do new drawings.
Most of our drawings are pretty basic.
I have attached an example of a typical drawing I have done in Visio.
I was hoping there would be some free IEC symbols or a title block I could use that would be enough to do some similar drawings.
Old March 29th, 2011, 06:58 AM   #8
Hydro Power Guy
Canada
Hydro Power Guy is offline
Hydro Power Guy's Avatar
You should be able to go into visio and copy the title block. Next open up AutoCAD and paste it in.
Or...
Some versions of visio allow you to save a visio drawing as a .dwg file. You can start with a visio title block and save it as an AutoCAD file. Then whenever starting a new AutoCAD file, just open the title block and do a save as.
There is a way in AutoCAD to make a particular file your default new template. I don't remember how off the top of my head, but I know it is possible. So you could take the converted title block and set it as your default.
Old March 29th, 2011, 09:34 AM   #9
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I would suggest that you get your drawing standards down as much as possible early on into your Autocad usage, and then build your symbol library to fit.
It is really pretty easy to build up a good set of "blocks" that include parameters (data items which can change like component names and specs) even without all the fancy tools in Electrical.
I started using Electrical here, because we own it, not for any other useful reason. For what I do, it is very much overkill, and our existing drawings are so "scatterred" in their standards that I can't really take much advantage of all the cross referencing and reporting tools.
I have used the RSLogix import/export tools once, and I have used the Electrical Components library quite a bit to add new things, but the time savings offered by those features is marginal and requires a bit of learning that you avoid altogether by using Autocad standard and "roll your own" symbols.
I used AutoCad Lite 98 for years and it was more than plenty capable, but the symbol library I built up is not IEC so would be of little use to you.
Even if you can't export/import your Visio elements, you can certainly drop them in as jpegs and trace over them. I do this all the time to ensure accuracy when creating new blocks from user manuals.
I typically use paint.net to invert/adjust colors of the bitmap then CTRL+A+C (click on the acad model) +V, then stretch it to my grid, and draw a with a contrasting color right over the top of it. Once your object is drawn, use the wblock command to save it in your tabset subfolders and you can reuse it from that point forward with a few clicks.
I suggest you document your practices as far as sheet sizez, layer usage, grid/snap settings, and symbols layout, and then stick with it from the beginning so you don't end up having to constantly adjust the objects down the road.
There is no reason you can't assign layers the same way Electrical would to make the end results more compatible with corroborators who have that package. The electrical version of Autocad is just a more automated version of what can still be done manually with regular Autocad. If you cranked out lots of designs from concept to assembly drawings, then it would be worth it. In my case, I think I would need to go to some professional training to really know what I am doing with electrical, but I have been able to get by and learn some of it as I go.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
"You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway."
Old March 29th, 2011, 11:07 AM   #10
Manglemender
United Kingdom
Manglemender is offline
Quote:
Ian
We too are about to change from WS-CAD to something else. We had a demo in the office of Promis-e and it looked very good right up to bit about £600/year maintenance contract - per seat! £600/Year for the office wouldn't be too bad but per seat?
I read the comments in the previous threads with great interest but I wondered what users of current versions felt about Promis-e?
An Autocad Electrical demo will no doubt be coming my way soon.
Nick
Old March 29th, 2011, 03:26 PM   #11
brendan.buchan
Australia
Thanks for the info again.
There is no way to export symbols from AutoCAD Electrical's IEC library so I can use them in AutoCAD is there?
Otherwise it looks like I may have to spend a fair bit of time making up my own.
Old March 30th, 2011, 12:46 PM   #12
shooter
Netherlands
shooter is online now
shooter's Avatar
Yes you can export symbols, however it is full of layers and extra info as there is running a database under it.
I am using autocad electrical and ELWIN Trial is free, it costs a whopping 30 euro)for each machine used.
i used caddy (SEE ) before.
I do have all symbols in acad.
just post your mail and i will send them
__________________
shooter@home.nl
skype paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old March 30th, 2011, 02:30 PM   #13
brendan.buchan
Australia
My email is brendan.buchan@berryrewind.com.au
Thanks.
Old March 30th, 2011, 10:44 PM   #14
rstech
Canada
rstech is offline
I used standard AutoCAD for the past 7 years and just bought AutoCAD Electrical a few weeks ago. I made all my own blocks. It didn't really take very long and they got alot of use over the years. Initially I spent about 8 hours to develop the title block and all the blocks I could think of including various switches, safety relays, I/O cards, etc. Then whenever I was doing a drawing set if I needed something that wasn't in my master template I would create the object and then save the block to my master template. It worked very well.
I'm looking forward to using AutoCAD Electrical. It looks like it has a lot of nice features. I just need to find the time to set it up!
__________________
Rob
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AutoCad 3-D modeling for mechanical drafting. OkiePC LIVE PLC Questions And Answers 23 November 2nd, 2010 10:03 AM
schematics John Hawkins LIVE PLC Questions And Answers 5 August 10th, 2007 03:31 PM
Autocad 2007 Lt Help PLC_NEWBIE LIVE PLC Questions And Answers 5 May 23rd, 2007 08:15 AM
drawing electrical prints 2004sk4 LIVE PLC Questions And Answers 38 July 10th, 2006 11:22 PM
AutoCAD Electrical Greg Dake LIVE PLC Questions And Answers 3 July 3rd, 2005 10:29 AM
