plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 28th, 2011, 04:01 AM   #1
prudent98
India
prudent98 is offline
SLC 5/04 serial port RS-232 and Panel view is supports RJ45
I want to connect a Panel View 300 through Ethernet to an SLC-5/04.But my PLC support RS-232/DH+ and would appreciate some advice on connections etc. please. I have been reading the 2711-UM014 manual, but am still a bit unsure what additional cables and equipment that I need to achieve what I want, if indeed, I can.
Based on the model number, I believe that the PV300 is support RJ45(Ethernet).
Based on the model number, I believe that the SLC 5/04 is support RS-232.
Any help would be appreciated...
regards
Prudent
Old March 28th, 2011, 04:11 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Just for checking, please specify the EXACT type number of the PV300.
There is no PV300 with ethernet support.
There are several models with DH485 support. One model has an RJ45 port for DH485, but at the expense of the RS232 port.
This PV300 with DH485 only is not a good fit for connecting to an SLC5/04.
You could connect both SLC5/04 and the PV300 to DH485, but it will be a cludge.
I would replace either the PLC or the panel so you get a combination that supports each other natively.
Curious: Since yu have been reading the manual already, how can you have gotten the idea that the PV300 supports ethernet ?
__________________
Jesper
3 strikes and you're out
Old March 28th, 2011, 04:15 AM   #3
prudent98
India
ohhh sorry actually Panel view not PV300 it's other make it's AB panel view.But it's onlt support to the Ethernet.
Plz give a solution for slc 5/04 Rs-232 port how to convert as a ethernet RJ45
Old March 28th, 2011, 04:21 AM   #4
rdrast
United States
rdrast is offline
rdrast's Avatar
RJ45 has nothing to do with Ethernet. It is a telephone company standard. The labeling of it as "RJ45" is a persistent error in the manuals.
The 8P8C jack on the PV300 is neither RJ45, nor Ethernet. It is a DH-485 connection. The SLC5/04 processor can connect to the PV300 using either DF1 (Serial RS-232) with a serial cable, or using a 1761-NET-AIC coupler to communicate over DH-485.
The 1761-NET-AIC still uses up the serial port on the SLC processor.
Look up the 1761-NET-ENI to enable the serial port of the SLC5/04 to bridge to Ethernet, but it may not function as you wish depending on what the "Other Brand" Panelview is looking for comms wise.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old March 28th, 2011, 04:28 AM   #5
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
How hard can it be, to just post the EXACT type no ?
__________________
Jesper
Old March 28th, 2011, 04:29 AM   #6
prudent98
India
k thank u so much and can i communicate with three SLC 5/04 processor to one Panel View
Old March 28th, 2011, 08:49 PM   #7
sthompson
Canada
sthompson is offline
sthompson's Avatar
Quote:
Apparently very hard Jesper.
Prudent98:
Please post the exact manufacturer and model number of your HMI. Otherwise, you are just making it difficult for people to help you.
If it is an AB PV300, it will have a part number something like 2711-K3A2L1.
Stu....
__________________
There's never time to do it right, but there is always time to do it over!
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
slc 5/04 serial comm problem with panel view plus 600 simmo231 LIVE PLC Questions And Answers 8 March 17th, 2011 03:06 PM
Slc 5/03 With Panel View prasadgaru LIVE PLC Questions And Answers 4 December 2nd, 2008 09:45 AM
panel view 550 to slc 5/03 rbc_maintenance LIVE PLC Questions And Answers 5 June 18th, 2006 07:46 AM
Panel View 550 DH485 with Printer Port Bill@PSI LIVE PLC Questions And Answers 6 March 26th, 2006 06:58 AM
Communication between PanelView 1000 and SLC 5/04 RP LIVE PLC Questions And Answers 50 December 9th, 2003 12:50 PM
