kglwin connection problem with plc
djhowelle
Jan 2011
las piñas city
good day to all,
I'm currently working on a project using master-k K3P-07AS plc and I'm having problem communicating my pc to the plc.
I already followed the instruction manual for communication setting but still I cannot communicate to the PLC.
I'm using a serial to Usb converter, is there any exact configuration in my device setting like baud rate,stop bit, etc.?
I also check my rs-232c cable wiring and it is correct. 2-3, 3-2, 5-5 as follows.
hoping for a kind resposne.
thank you and more power...
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
84
Hello, I have an issue where I want to simulate an Siemens HMI panel, through NAT connection to a PLC. I have the possibility through extended...
129
Hello guys i'm working with an s7 1200 plc with an ET 200S expansion module. The problem is that i can't find the plc when searching in the...
108
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
111
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
157
