This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Apr 2011
Learning Ladder Logic
Hey all.
I am in the process of learning ladder logic, and having grasped the basics, have decided to set myself a real life application project, to test myself. I wanted to share it with you all, to see what logic you would create to solve the problem. I haven't been able to complete this, as I am only able to use the online simulator (I don't have a PC) Find the application below. I'd love to see if someone could solve it using the simulator! (http://www.plcsimulator.net/plc.php ). Fluid dispensing into bottles - test application On/Off Switch for entire process. Sensor to detect if there are bottles on the conveyor. Output to move conveyor. Sensor when empty bottle is under dispenser to stop conveyor Timer to run fluid pump until bottle is full. Conveyor to start until another empty bottle is under dispenser. (NB obviously times weights etc are whatever you want them to be) |
#2 |
![]() Join Date: Mar 2006
What exactly are you asking -- can someone do it using the simulator? If so, the answer is "YES"
If you're asking for someone to do your homework for you, the answer is "NO"
__________________
"I wonder how people did this before the days of PLCs?" If people would take the time to learn how a simple relay control circuit works..... [Helliana] |
#3 |
Post your simulator file so those who use it can check it out and give comment.
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#4 |
@ OZEE - No homework here, just trying to learn some new programming skills.
@ bernie_carlton - I didn't get very far - How can i post it here? ![]()
#5 |
Read the board instructions here
__________________
#6 |
find attached . It's not complete.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flow Ladder Logic | slenkovj | LIVE PLC Questions And Answers | 14 | May 14th, 2013 01:05 PM |
| Simple ladder logic modification | canntec | LIVE PLC Questions And Answers | 1 | October 22nd, 2010 04:05 AM |
| Ladder Logic, Line-by-Line, Flowcharting | recondaddy | LIVE PLC Questions And Answers | 10 | March 18th, 2010 09:39 PM |
| Need help with ladder logic problem | RickGilbert | LIVE PLC Questions And Answers | 10 | June 5th, 2005 01:38 PM |
| Ladder Logic Editor | Shafiq | LIVE PLC Questions And Answers | 4 | May 19th, 2003 11:44 AM |
