plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 15th, 2011, 05:30 AM   #1
Lilith
Bosnia
Lilith is offline
RJ45 to RS485 pinout
Hi guys!
I'm trying to build a cable to connect twido plc (RS485) and altivar71 (RJ45). Anyone knows pin-out for this connection? Does it matter which ethernet cable i use (a or b, images attached)? Thanks!
Old April 15th, 2011, 10:12 AM   #2
kittydog42
United States
kittydog42 is offline
kittydog42's Avatar
It should be a fairly easy connection. It doesn't matter which type of Ethernet cable you use since the RJ-45 connector doesn't actually use Ethernet at all, and you only need positions 4 and 5 which are the same colors on both types. You'll connect the blue and blue/white pair to terminals A and B on the Twido. You'll have to try both polarities to determine which is correct.
Old April 15th, 2011, 10:20 AM   #3
Lilith
Bosnia
Lilith is offline
So i don't need to use the third pin (SG) on rs485 connector? I will try that, thank you very much!
Old April 15th, 2011, 11:13 AM   #4
kittydog42
United States
kittydog42's Avatar
If you have any issues, connect the brown wire from the Ethernet cable to SG.
Old April 26th, 2011, 05:12 AM   #5
Lilith
Bosnia
Lilith is offline
Quote:
Thank you, i've made the cable but i'm still unable to start the motor. I use following devices:
HMI XBTGT 4330 7"
Programming software: VijeoDesigner 4.6.0.7613
Twido PLC TWDLCAE40DRF
Programming software: TwidoSuite 2.0
Altivar 71
Ethernet communication between HMI and PLC works fine, i can set the speed on HMI and correct value is displayed in animation table on PLC. I used following settings on Altivar:
Communication - Modbus Network:
Address: 2
Baudrate: 19200
Data bits: 8
Time between frames: 10
Command: Ref.channel 1: Modbus
Ch1 active
Profile Not separ.
System word %SW64 keeps returning (modbus) error code 8. I have NST message on Altivar with these settings; if I try to use I/O profile it says RDY but does not receive anything from PLC, or returns CRC 2. I've read manuals, checked wiring and tried pretty much everything I could think of, but no luck
HMI and Twido programs are included in attachment. I would be very grateful for any suggestion regarding this issue. Tyvm!
Old April 27th, 2011, 08:28 AM   #6
tpiatkowski
Canada
tpiatkowski is offline
Looking over your Twido program I have noticed that both RS485 ports (mini-din) and the terminal block option block share the same Modbus address of 1.
Old April 27th, 2011, 09:30 AM   #7
Lilith
Bosnia
Lilith is offline
Thanks, i'll try to change it and see if it works .
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SEW Movidrive RS485 pinout jetuaime81 LIVE PLC Questions And Answers 0 May 7th, 2010 02:20 AM
Pinout for RJ45 connector on Magelis for RS232 jjm5jjm5 LIVE PLC Questions And Answers 4 February 3rd, 2010 12:02 AM
RS485 15 pins to RS485 9 pins !! manmeetvirdi LIVE PLC Questions And Answers 6 June 29th, 2009 10:14 AM
RS485 / RS422 Connection Bridge johnyu LIVE PLC Questions And Answers 4 March 12th, 2007 07:44 AM
Easy? PLCs to RS485 mike123 LIVE PLC Questions And Answers 13 October 23rd, 2006 07:08 PM
