This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
What is this for? GE fanuc 90-30 MOVE INT etc..
HI GUYS,, what is "length",
for what is it? can anyone help me with this? the "4" is chosen from range 0-256 (256 is the limit) Thanks |
#2 |
does it mean 1-256 is decimal number?
#3 |
In my case, %R00008 is the quotient from DIV INT
so the quotient is in INT type of data then will move to AQ0001. Im confuse about the 1-256 length Thanks for your reply |
#4 |
See PDF below for instruction help.
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#5 |
By the way, the manual is very helpful
thanks! |
#6 |
Sir I think the length is the number of bits to be move, in my case , when move int is activated %R0008,%R0009,%R0010,%R0011 will be moved to AQ0001 AQ0002 AQ0003 AQ0004..
Is this correct? Last edited by fhervrylesestoso; April 27th, 2011 at 01:19 AM. |
#7 |
You are correct. If, instead of %R0008 at the "IN" node, you had a constant, then that constant would be copied to all four destination addresses.
#8 |
OK Sir, Thank you very much for your answers...
Cheers! |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ge fanuc 90 -30 programing using lm 90-30 | mamadoo95 | LIVE PLC Questions And Answers | 3 | March 25th, 2011 11:29 AM |
| Fanuc 90 30 Programming manual | widelto | LIVE PLC Questions And Answers | 2 | October 31st, 2009 09:56 AM |
| Confused "again" S7 indirect | Thim | LIVE PLC Questions And Answers | 17 | July 22nd, 2008 04:47 PM |
| GE Fanuc 90 30 info | leitmotif | LIVE PLC Questions And Answers | 3 | August 4th, 2007 12:52 PM |
| GE Fanuc Series 90 30 | Johnny T | LIVE PLC Questions And Answers | 14 | June 16th, 2004 01:13 AM |
