DC into AC PLC inputs
Nov 2007
Illinois
75
I know this can be solved by using an interposing relay, but I'm trying to reduce cost. We have an application that has several AC inputs and 1 DC input - 24VDC, and I would like to use an Eaton smart relay. Can the AC inputs "see" a 24VDC input, or maybe a higher VDC? I'm more of a programmer, so I really don't know the behavior of the I/O in this situation.
Thanks!
as stated i would keep the interposing relais option but maybe finding a micro size modele as it does'nt need much output current anyway
You may look at your input card construction and maybe their is some made with rectifier diodes on the AC side to actually trigger the input with DC voltage meaning it would work with DC at same voltage level. But the usual one i use got optocoupling where i don't believe would work on DC
Whenever you try to cheat the system, it WILL come back to haunt you in the future. Do it right the first time.
I guess I don't understand the savings. How can a $20 relay be offset by the cost of the engineer/designer time.
I would expect that you already spent at least 1 hour looking into this so if you do save the $20 relay, it is more than offset in labor.
This is a case where hundreds of this unit would go out in a year, so over time the savings would be pretty substantial.
My thanks to Jeff23spl for at least answering the question.
the input will work as most AC inputs have a diode bridge
outputs are not compatible as the AC is a Triac and DC is a transistor
I'm not a Eaton smart relay user so I will ask,
are the inputs isolated ( don't mix Ac with DC). Is there one neutral connection. If so how would the DC input find a return.
As other have said don't do this. $20 buck would be an expansive relay
you can get a base and relay for under $10.
Hello I need to message read the entire 16 channel raw analog inputs from a 1769-L33ER Compact Logic controller to another 1769-L33ER Compact...
243
Good morning guys; Im new at AB plc, and i just need help about a table or a list called something like "exchange data table" in French it is...
777
What he have is a HMI2GO unit ( KTP900F) and we use a safety relay to trigger our e-stops. What the tech wants to do is guard against e-Stop on...
1,860
Most PLCs are 24v for digital logic, will a Digital input card detect a 12v (automotive) signal as a 1 Looking to do some work on a...
4,295
Hello PLCs.net! I have a kinetix 5500 drive connected to a gantry, I was wondering if there is a way to do active homing using a PLC tag? At this...
3,057
