plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 6th, 2011, 08:57 AM   #1
nightline
Netherlands
nightline is offline
Simatic PC Adaper USB with Virtual PC....
Gents,
I've a Laptop with W7 64 running, and MS Virtual PC for WindowsXP.
On this WindowsXP I've installed Siemens Step 7 V5.4, and like to attach my Simatic PC Adapter USB.
When connecting this Adapter and attach in Virtual PC, the driver is installed, but gives the error code 10 ( driver cannot start ).
Can anyone give me some tips to solve this problem?
Jack
Old May 6th, 2011, 10:19 AM   #2
Homer_BL
Bosnia and Herzegovina
Homer_BL is offline
Hi!
As for my expirience, try to avoid Virtual machines when using Siiemens sw. It will never work fine. I tried to istall Step7 V10.5, it failed.
Now I have Multiple OS (C: - Win7 32, D: Vista 32) instead of VM and all works fine.
Old May 9th, 2011, 07:25 AM   #3
Krcedinac
Serbia
Krcedinac is offline
Krcedinac's Avatar
Hello,
I also have W7 64, multple VM running Siemens software and they all work perfectly. I have Premium Studio 2009 on one virtual machine and PCS7 v7.1 SP2 on another and my old lap top converted to virtual running all kind of PLC software.
Only I am using VMware instead of MS Virtual PC. I used PC Adapter and CP5711 without any problems...
Old May 9th, 2011, 07:48 AM   #4
nightline
Netherlands
Quote:
Originally Posted by Krcedinac View Post
Hello,
We are not allowed to run VM ware on our systems by our IT guys, so I've do it with VM.
My Siemens Simatic Manager is version V5.4.0.0 without any service pack. So maybe this is part of the problem.
Where can I download these service packs?
Regards,
Jack
Old May 9th, 2011, 08:38 AM   #5
Krcedinac
Serbia
Krcedinac's Avatar
Hello,
I do not think that you have problem with Simatic Manager. Here you can find drivers for USB adapter:
https://support.automation.siemens.c...94&caller=view
Try with this and see if it works...
Also if you want here is SP5 for Simatic Manager:
https://support.automation.siemens.c...84&caller=view
Old May 9th, 2011, 09:31 AM   #6
STL???
United Kingdom
STL??? is offline
Gave up with Virtual PC, VMware works well except for PCMCIA support.
Old May 9th, 2011, 10:57 AM   #7
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
I have a copy of Microsoft's Virtual PC. The last time I checked it didn't support USB.
I run Step 7 on my VM Ware. It works well with both Profibus and Ethernet. Our product also has a USB port and that works with the VM Ware too.
Edit, I am actually running VMWare's Fusion on my Mac Pro at work.
__________________
"Living is easy with eyes closed, misunderstanding all you see...." Strawberry Fields Forever, John Lennon
Old May 9th, 2011, 03:51 PM   #8
cjd1965
United Kingdom
cjd1965 is offline
Hi I have Step7 running under XP Mode of win7 pro.
Remember to install the USB driver under win 7 and inside the VM... and use the USB menu to attach it before use.
My gripe is that the Step7 VM hard drive is getting very bloated.
Cheers
Old May 10th, 2011, 06:19 AM   #9
nightline
Netherlands
Cheers
Can you explane a little more what you mean with installing the USB driver under W7 and inside VM?
Which version of driver and USB adapter are you using?
Jack
Old May 10th, 2011, 04:35 PM   #10
cjd1965
United Kingdom
cjd1965 is offline
Hi I have a standard genuine siemens usb adaptor with the supplied cd.
basically install the drivers so win7 recognises it. Then attach it to the virtual machine (see menu bar - usb - select from list - attach)
Then install driver under the virtual pc (xp pro in my case)
Then select usb adaptor, auto settings, within the virtual pc control panel
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens PC adapter USB. JesperMP LIVE PLC Questions And Answers 9 March 16th, 2005 02:01 AM
simatic pc station donald_soft LIVE PLC Questions And Answers 0 February 23rd, 2005 11:21 AM
Virtual PC control Txema LIVE PLC Questions And Answers 9 November 6th, 2004 09:04 AM
Virtual PC & Modsoft golarger LIVE PLC Questions And Answers 7 July 1st, 2004 08:59 AM
Simatic PC PG710 II Manuals cncbob LIVE PLC Questions And Answers 0 June 29th, 2002 02:38 AM
