plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 12th, 2011, 11:31 PM   #1
LeiconJames
Australia
LeiconJames is offline
nettoplcsim multi-instance
I'm using nettoplcsim to simulate an S7PLC / SCADA project.
It works brilliantly to allow PLCSim to communicate with our SCADA software via an OPC server.
I'm just wondering if anyone knows of a version that allows connection to multiple instances of PLCSim as we have 3 PLCs in our project.
James
Old June 13th, 2011, 04:26 AM   #2
Thomas_v2
Germany
Thomas_v2 is offline
Hi James,
there is a new version of nettoplcsim which supports multiple instances.
At this time it is only available via SVN repository.
If you have a SVN client just check out the multiinstance branch, or download the 3 files (Interop.S7PROSIMLib.dll, Nettoplcsim.exe and noDaveServer.dll) from http://nettoplcsim.svn.sourceforge.n...ttoplcsim/bin/
You have to start nettoplcsim for every plcsim instance you have started, and set by menu "settings" to the IP address nettoplcsim has to listen to, and the plcsim instance number you want this nettoplcsim instance to connect to. The instance number you will see in the plcsim title ("S7-PLCSIM1" is instance number 1).
You need as many IP addresses on your network interface as many plcsim instances you want to connect to.
You can add an additional IP address in the properties menu of your LAN connection, and there in the extended menu (I don't know the exact label names in english windows versions).
Thomas
Old June 13th, 2011, 08:05 PM   #3
LeiconJames
Australia
Hi Thomas,
thanks for the reply and for the great software.
I have downloaded the latest version as per your link however I can't see the menu "settings".
Also I am running PLC sim and the OPC software on the same computer and currently connecting to the "localhost" with the single instance of plcsim. Do I still need to set up multiple IP adresses?
James
Old June 14th, 2011, 12:13 PM   #4
Thomas_v2
Germany
Quote:
Ups, sorry. This is the correct path to the multiinstance version:
http://nettoplcsim.svn.sourceforge.n...m/bin/Release/
You need the multiinstance version if you want to start your 3 Plcsim instances at the same time, and connect a scada or your OPC server to all simulated PLCs.
If you are using the "normal" Nettoplcsim version, it connects by default to the first Plcsim instance. So if you only want to test a single Plc with a single Scada/OPC connection at one time, it's not neccessary to run the multiinstance version.
I haven't released the multiinstance version as official release, since the option to start more than one Plcsim instance simultaneously came with a later servicepack of Step7.
Old June 15th, 2011, 02:54 AM   #5
LeiconJames
Australia
Thanks Thomas, that works great.
FYI I am using this with PLCSim 5.4 SP4 and TopServer 5.4.
I have had it running with 2 instances of PLCSim with no problems so far.
Thanks again for the excellent software.
James
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens 300 Multi Instance FB JOLTRON LIVE PLC Questions And Answers 10 April 20th, 2010 01:47 PM
S7 Common ODT in multi instance FB Longhorn LIVE PLC Questions And Answers 5 November 5th, 2009 07:40 AM
S7 - Address Registers from Multi Instance JayD LIVE PLC Questions And Answers 6 September 13th, 2009 01:17 AM
Multi Instance FB's JOLTRON LIVE PLC Questions And Answers 6 August 19th, 2009 05:08 AM
S7 Population of AR2 for a multi instance FB jdf LIVE PLC Questions And Answers 10 November 21st, 2008 01:44 PM
