PDF Issue - Eplan 5 Font - EPL5_437
STL???
Sep 2005
UK
879
We have recieved an old machine with no schematics, i have found a Cd containing the original schematic in PDF form.
When i try to open it with adobe, it asks for the following font:
EPL5_437
It seems without, the text display is garbage.
Does anyone use Eplan 5 and if so would they mind attaching the font file?
Thanks.
I would think that there is a way to substitute another font for that one. Do you have an Abode PDF creator of some sort? Could you post the file?
i only have a PDF reader installed unfortunatley, i can't post the pdf either due to Company confidentiality rules.
Its a Specific Font to Eplan5 schematic drawing software.
Usually the fonts are embedded in the document, so if someone doesn't have the correct font, they won't have the issue taht you do. I don't know what's special about that font, but there must be someway to substitute another.
I have a similar problem.
I need a font - EPL5_850 - in order to print out old PDF files (from 2006)
with PLC drawings/documentation for an old machine installation.
I think that the original documentation where made with EPlan 5.2.
Thanks in advance.
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
173
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
130
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
400
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
537
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
552
