plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 7th, 2011, 12:31 AM   #1
frt
United States
frt is offline
Data manipulation- moving average
Hi all,
I am pretty new to the PLCs and I had a question about data handling.
I get readings from a pressure sensor and display it to the screen (I use EZSeries) the thing is, the pressure sensor readings fluctuate so much and I need to stabilize it somehow. I want to apply a moving average on the data and then display it to the screen. Is such thing possible ?
Thank you
Old July 7th, 2011, 12:35 AM   #2
KalleOlsen
Norway
KalleOlsen is offline
Quote:
Originally Posted by frt View Post
Hi all,
Thank you
You want to put moving average routine in the PLC? Yes, it is possible.
PLC make/type?
Kalle
Old July 7th, 2011, 12:44 AM   #3
dcooper33
United States
dcooper33 is offline
dcooper33's Avatar
Hi Frt,
Yes, that is certainly possible. Two questions: How often do you need to take readings, and how often do you want the average updated?
Old July 7th, 2011, 07:07 AM   #4
danw
United States
danw is offline
danw's Avatar
Not to sidetrack a PLC solution but some pressure transmitters have a setup parameter typically called damping that smooths the output of the pressure transmitter.
Old July 7th, 2011, 07:56 AM   #5
Mickey
United States
Mickey is offline
Mickey's Avatar
First why does it fluctuate so much?
If your EZseries supports math instructions then a simple filter might work for you.
Quote:
FV=FV+C(NV-FV)
Where:
FV= Filtered value
C= constant (range 0-1) The smaller the number the more dampening.
NV= New Value
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old July 7th, 2011, 10:43 AM   #6
dcooper33
United States
dcooper33's Avatar
I'm not familiar with EZ series, but here is a way to do it on an SLC processor that is fairly simple.
Old July 9th, 2011, 04:23 AM   #7
shooter
Netherlands
shooter is offline
shooter's Avatar
mickey easy and simple that is what i like.
good
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old July 14th, 2011, 12:44 PM   #8
frt
United States
frt is offline
Mickey thank you very much. The fluctuations decreased significantly. never thought that it would be this simple.
Also thank you all for your ideas and suggestions
Frt
Old July 14th, 2011, 01:05 PM   #9
Mickey
United States
Mickey is offline
Mickey's Avatar
Frt
Your Welcome.
__________________
Mickey
Old July 15th, 2011, 10:58 AM   #10
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
NO! The pressure fluctuations ARE STILL EXACTLY the same as they were. The only thing that decreased significantly is the fluctuations in YOUR DISPLAY OF THE PRESSURE.
This is something to keep in the back of your head. Most likely, for all normal every-day uses, your new average pressure will be what you want to use. At the same time you need to be aware of what the REAL pressure is doing - jumping around all over the place. At some time for some other use, this could be important.
For example, for controlling the draft pressure in certain gas and wood-fired boilers, it is important to keep the pressure from ever going positive. Positive pressure in the burn chamber can result in dangerous gases being expelled into an occupied area.
You can average this pressure over some time period to get a nice display number that is easy to read and follow, but at the same time, for the draft pressure controller, you must not use too long of an averaging time period to control the draft, otherwise it will go positive too often.
Old July 15th, 2011, 11:17 AM   #11
FrancisL
United Kingdom
FrancisL is offline
I dont know about EZSeries PLC's, but many provide a first or second order filtering as standard, my control theory memory suggests this would be better than a moving average .
Or as DANV said the transmitter itself may provide filtering (damping)
__________________
Keeping it Simple takes thinking time.
Old October 7th, 2011, 02:11 AM   #12
Luked
Australia
Luked is offline
BMACATTACK - What you have programmed is useful, however it isn't strictly a moving average, it is a 10 second average with 10 samples, updated every 10 seconds. A moving averge continuously updates every sample, by deleting the last sample, summing the values and dividing the sum by the number of samples. The major difference is that moving average updates every sample.
Old October 7th, 2011, 07:00 AM   #13
Clay B.
United States
Clay B. is offline
Clay B.'s Avatar
Quote:
FV=FV+C(NV-FV)
Where:
FV= Filtered value
NV= New Value
Mickey,
I am so glad you posted this formula again. I was looking for this for a job I am working on right now and going thru all of your posts would have been a difficult task.
Thanks,
Clay
Old October 7th, 2011, 11:05 PM   #14
Luked
Australia
Luked is offline
I thought this might be useful for everyone who programs with RSLogix500, the attached document explains code for a MOVING AVERAGE otherwise known as a 'running average'. It uses the FIFO instruction as a clever way to control words. SLC_running_average.pdf
Old October 7th, 2011, 11:11 PM   #15
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
Originally Posted by Clay B. View Post
Mickey,
Thanks,
Clay
Your welcome.
__________________
Mickey
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Moving a data problem fpaezp LIVE PLC Questions And Answers 6 June 15th, 2011 04:28 PM
For fun and learning. SMOKE LIVE PLC Questions And Answers 42 April 14th, 2010 10:53 AM
Saving data in PLC - possible? flyers LIVE PLC Questions And Answers 24 October 29th, 2006 09:45 PM
Moving data into a bit shift josepa LIVE PLC Questions And Answers 2 October 17th, 2006 08:37 AM
Hourly PLC Data Average for Each Scan mfeby LIVE PLC Questions And Answers 8 June 14th, 2006 09:52 PM
