plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 19th, 2011, 07:19 AM   #1
Terrence_H
United Kingdom
Terrence_H is offline
Smile RSNetWorx for DeviceNet version conflict?
Hi all.
I am kinda new at the RSNetWorx thing, but know just a little. The probelm I have is That I am setting up a new Network with only 2 nodes.
One is the 1769_SDN scanner and the other a 3rd party Servo Drive (Control techniques).
The problem I have is that I am trying to configure the SDN scanner with RSNetWorx, When I go "Online" to the network it sees the 1769-SDN scanner but says it is not recognised. I have loaded the EDS files for that SDN scanner. But still says not recognised. If I double click on the Not Recognised device, it says it is not registered. So I try registering it again with the EDS files, but still says not recognised.
Is it because I am running a old version of RSNetWorx. and not a new version.
I have version "Revision Product" 3.21.00 (Build 27)
The SDN scanner has Major Rev 4 and Minor Rev 2.
I have double checked the EDS fiels and am certain I am loading the correct EDS files, (infact I loaded all 4 files to make sure)
Do I need a New Version of RSNetWorx, maybe version 10 that is out? Hopefully I can use it as a Demo version as I don't need the full version. (just useing 2 nodes)
Thanx
Old August 19th, 2011, 07:21 AM   #2
Terrence_H
United Kingdom
Ah Thought I'd just mention that the RSNetWorx network sees the Control techniques drive and I maped it and everything. Just trying to do the same with the SDN scanner.
Old August 19th, 2011, 07:33 AM   #3
Terrence_H
United Kingdom
After trying to register the SDN, I get this Message:
The Following error occurred parsing the EDS file: ' Invalid entry in memory Table's'. Contact your vendor for an updated EDS file.
Now I have downloaded the newest EDS file from the AB website,and this is that is the message I get, so I know I have the correct EDS file. You think it is the RSNetWorx Software I need to upgrade ?
Old August 19th, 2011, 10:01 AM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
RSNetworx v3 was released long before the CompactLogix existed, so it's probably choking on the 32-bit definition for the scanner's I/O table. It's probably more than ten years out of date.
Get RSNetworx for DeviceNet v10. The software still works in "demo mode" for nodes 0 through 5.
You'll have to get it through your RA distributor; it's not a free download, because the demo mode was only distributed as part of Starter Kits.
Old August 23rd, 2011, 06:58 AM   #5
Terrence_H
United Kingdom
Thank You Ken, I'll see if I can get a v10 from my distributor. I will post back if al works.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
b & r version conflict schrader LIVE PLC Questions And Answers 10 February 15th, 2011 04:54 PM
Version Problem for Rockwell E3 module Eric Le Yin LIVE PLC Questions And Answers 4 January 22nd, 2009 01:05 AM
RSLogix 5000 Version Conflict sadanand_kulkarni LIVE PLC Questions And Answers 5 January 18th, 2009 12:57 AM
rsview32, using newer version of works editor with older version of runtime diat150 LIVE PLC Questions And Answers 7 February 11th, 2008 12:27 PM
Proworx Demo Vs. Full Version CONTROLTESTGUY LIVE PLC Questions And Answers 2 January 25th, 2006 01:45 PM
