plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 21st, 2011, 09:53 AM   #1
Old No. 7
United States
Old No. 7 is offline
Micrologix 1400 RTC
I have an application where I'm trying to sync a HMI clock with the Micrologix RTC. I finally got everything working, but I found one fairly major issue. If you send the time/date while the RTC is disabled, the PLC will fault. What I would like to do is have the PLC program enable the RTC, but I don't think this is possible. The only way I can see is to enable it through RS Logix.
Old August 21st, 2011, 11:29 AM   #2
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Apparently you can disable the RTC by writing all 0's to RTC Words 0 thru 5, which contain the date and time fields. I don't know, if you then write the current date and time into these fields, whether the clock will restart.
Old August 21st, 2011, 06:27 PM   #3
Old No. 7
United States
I did confirm that sending zeros to all the time/date fields will disable the RTC. Unfortunately, sending it time/date values when it is disabled will fault the PLC.
It's easy enough to prevent the fault by not sending values if the RTC:0/DS (disabled) bit is set but it sucks that there is no way to turn it back on through the program. Since it defaults off when you get a new PLC, I'm worried about our guys forgetting to turn on the RTC manually through RS Logix during startup.
Old August 21st, 2011, 09:03 PM   #4
Mickey
United States
Mickey is offline
Mickey's Avatar
The manual says the RTC:0/DS is read only. You can probably use that bit in logic to
only allow your HMI to write to the RTC when it's enabled.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1400.... Brijm LIVE PLC Questions And Answers 16 March 17th, 2015 06:01 AM
micrologix 1400 configuration with rslogix 500 sruthi LIVE PLC Questions And Answers 4 April 7th, 2014 06:50 PM
MSG from MicroLogix 1400 to MicroLogix 1500 Marie1982 LIVE PLC Questions And Answers 3 September 3rd, 2010 10:46 PM
MicroLogix 1400 problem shoelesscraig LIVE PLC Questions And Answers 4 September 12th, 2009 04:41 AM
AB Micrologix 1400 - RTC ragsncl LIVE PLC Questions And Answers 2 August 11th, 2009 07:01 PM
