plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 25th, 2011, 06:42 PM   #1
rajy2r
Canada
rajy2r is offline
rajy2r's Avatar
VMWare Player vs VMWare Workstation
With the advent of Windows 7, i think i am looking into VMWare to run windows XP and older Rockewell Software.
I am unsure as to what the major differences (advantage/disadvantage) between VMWare Player and VMWare workstation are.
I am primarily looking for a setup to program PLC's & HMI's using AB software. I presume other software's will work too in case of a client wanting something different.
So just hoping to find out if its worth shelling the $189 for a workstation or the player has all the tricks in the bag.
Old August 25th, 2011, 07:09 PM   #2
Paully's5.0
United States
Paully's5.0 is offline
Player will do "MOST" everything you need, however I find these 3 features of workstation justify the price tag (if you search the net you'll find 15-25% off coupons)
1 - Cloning (easily duplicates a VM)
2 - Snapshots (allows you to go back and forth between VM states)
3 - Network Editor (allows you to chose specific network adaptors to run from)
Old August 25th, 2011, 08:30 PM   #3
jkerekes
United States
jkerekes is offline
jkerekes's Avatar
I too have VMWare Workstation and it is critical to my work. I probably only use about 60% of it's capabilities. But I do use the snapshot and cloning functions. Why don't you try Player and see if it meets your needs.
Old August 25th, 2011, 10:15 PM   #4
rajy2r
Canada
rajy2r is offline
rajy2r's Avatar
I have a demo of VMWare workstation running on my desktop, and it works great. I guess i am not looking for one seat, but looking for a department wise implementation (4-5 PC's/Laptops). Maybe a single VMWare workstation to setup and clone systems. Then everyone can run them in a player.
I guess i am trying to get a feel for how multi-user setups use it as.
I am not too sure why i would use a snapshot.
Old August 25th, 2011, 11:28 PM   #5
Dravik
United States
Dravik is offline
snapshots are handy to do just before you apply a patch or upgrade to the software. If it goes poorly(and it often does), you just roll back to the snapshot and are back where you started no harm no foul.
Old August 26th, 2011, 01:45 AM   #6
todster
United States
todster is offline
If you're planning on using it on several pc's, will you also plan on using the network to transfer files between the VM's? If you're planning on network access to the plc or for HMI definately go with 2 nics and dedicate 1 nic to the vm. You'll want to disable all power management and offloading on the host side. Neither HyperV nor Vmware(any version) can handle heavy utilization of the network from the VM's with certain host nic's, especially if you have a Broadcom (most Dell computers)or Nvidia nic.
Vmware server is free. It also allows remote access to the vm config and console via web browser.
As far as the network editor, it's included in the free vmware server, it is a stand alone and it does work with vmplayer.
I prefer the server. It's free and I can create and manage a vm remotely.
Old August 26th, 2011, 03:01 AM   #7
504bloke
England
504bloke is offline
504bloke's Avatar
I run Workstation for reasons given above also use VMWare Fusion on a mac (similar to workstation)
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Old August 26th, 2011, 07:50 AM   #8
Paully's5.0
United States
20% Off Workstation
You will easily cover the costs of Workstation by the amount of time your engineers will dink around with settings. If you have multiple nics on your computer, you may run into hassles with VMWare Player, as it picks which one do use...somehow. That is where the network editor saves me time. I have read that yes the network editor it is "stand-alone", but to get it for "free" outside of Workstation you have to go through some processes, which probably would take an hour or so to do.
How much time have you spent trying to figure out which route to go?
Old August 26th, 2011, 09:46 AM   #9
surferb
United States
surferb is offline
surferb's Avatar
I really like VMWare Workstation, but Paully nailed the differences. If you don't need those features, then the free version (Player) may likelyd satisfy your needs.
__________________
Nathan Boeger, CISSP-ISSAP, CCVP/CCNA, MCSE, VCP
"Design Simplicity Cures Engineered Complexity"
Comment on Not another industrial software Blog
Ignition by Inductive Automation, rethinking SCADA for modern manufacturing 2 minute video
Old August 26th, 2011, 11:08 AM   #10
todster
United States
todster is offline
There's also a utility that lets you mount the vmdk from the host.
http://www.vmware.com/download/eula/...nt_ws_v55.html
For those that use the player or won't because of the network config or actually lack of, Vmnetcfg is actually included in the vmplayer installer only it isn't installed.
To extract vmnetcfg.exe from the installer do the following:
1. Run the installer with /e option. For example:
VMware-player-3.0.0-197124.exe /e .\extract
Contents will be extracted to “extract” folder.
2. Open “network.cab” and copy vmnetcfg.exe to your installation folder,typically C:\Program Files\VMware\VMware Player\
Old August 28th, 2011, 08:54 AM   #11
gderrick1961
United States
gderrick1961 is offline
With Windows 7 Professional or Ultimate you can download Windows Virtual PC and XP Mode. I'm using it for 10 year old version of GE Fanuc VersaPro without problem. Price is right - free.
Old August 28th, 2011, 09:06 AM   #12
BNA
Denmark
BNA is offline
BNA's Avatar
I'm using the wm ware player for my old S5 for windows, and it works perfectly, i have tried the Windows Virtual pc as well, and I must say I'm not impressed, on my machine it was way to slow for me.
/Brian
Old September 19th, 2012, 09:15 AM   #13
RussB
United States
RussB is offline
RussB's Avatar
To add to the confusion... I mean options there are some "Open Source" VM's also.
VirtualBox
Xen
More Information here: Good place to start when looking for any FreeWare.
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old September 19th, 2012, 09:24 AM   #14
Passman
United States
Passman is offline
Quote:
VirtualBox
Xen
VirtualBox by Oracle is outstanding. I've been using that for a couple years now.
Old September 19th, 2012, 01:14 PM   #15
manmeetvirdi
India
manmeetvirdi is offline
Hi
VMWare workstation needs to be purchased. If your company can get a copy of it for you then go for workstation solution.
VMWare player is FREE. If you are a individual then go for player.
I'am using VMWare Player 5.0.0 which is a latest version and look alike of Workstation and with VMWare tools installed I have no reasons for going for workstation. With player you can copy paste files from host to virtual machine, you can share a folder of host machine, which you can then access from virtual machine. All is well with VMWare Player.
__________________
Manmeet
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1747-PIC and VMWare Player dmroeder LIVE PLC Questions And Answers 19 September 18th, 2013 12:58 PM
VMware Slow randy LIVE PLC Questions And Answers 18 November 7th, 2010 03:24 PM
RSLinx 2.56 in VMWare Player with XP Host Ken Roach LIVE PLC Questions And Answers 6 October 23rd, 2010 07:08 PM
VMWare workstation Version 7 Operaghost LIVE PLC Questions And Answers 5 November 22nd, 2009 10:32 PM
VMware anyone ? A few questions. JesperMP LIVE PLC Questions And Answers 16 December 21st, 2007 09:02 AM
