plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 14th, 2011, 09:50 AM   #1
Silence89e
Iraq
Silence89e is offline
Fancy Exclamation codesys V2.3 with FactoryTalk (OPC server)
hi.... i have an urgent problem, the case is am trying to connect FactoryTalk View 5.10 hmi with codesys v2.3, but i cant import tags from codesys to factorytalk.
codesys has an OPC server, and thus it should allow it to cannect to the factorytalk.
so what should i do???? pleas....
best regards.
Old September 14th, 2011, 10:23 AM   #2
Doug_Adam
Australia
Doug_Adam is offline
Doug_Adam's Avatar
I may be missing something, but I think the factorytalk will only import tags from Allen Bradley products. If I am wrong, could someone please say. I have only used this with Allen Bradley.
For Codesys to other HMIs, I usually have to enter stuff by hand. I speed this process up using spread sheets to create text files of tags that can then be imported into both the HMI and Codesys.
If I were you, I would try to first setup a single read and a single write tag manually, and then test your system to see if it works.
Sorry, but I don't think you are going to have an easy time of it.
Old September 15th, 2011, 05:37 AM   #3
iant
Australia
iant is offline
iant's Avatar
Are you setting up Modbus comms through OPC server
I have used KEPServer 4.6 for Twido to Panel veiw Plus
it has a large variety - But no Codesys - sorry
__________________
Give all the answers
- People seldom learn.
Guide People to the posibilities
- Their Answers will come easily.
- Their Knowledge will grow.
They will then teach others
Regards
Ian Trost
Old September 15th, 2011, 05:46 AM   #4
Silence89e
Iraq
thanks Doug Adam for your reply...
i have seen somewhere that factorytalk can connect to any application that have an OPC server, but i am having a real hard time here.
rdrast, a member here, told me i may be possible.
i know its better to use factorytalk with AB products, but in my situation i have a licensed factorytalk and an ABB PLC, this PLC uses Codesys as its programming software but its HMI is very poor.
do you know a better software to program ABB PLCs that have a good HMI or can be easily connected to factorytalk??
Old September 15th, 2011, 05:50 AM   #5
Silence89e
Iraq
thanks iant...
no actually am having an ABB PLC, this PLC uses Codesys as its programming software but its HMI is very poor.
Old September 15th, 2011, 05:51 AM   #6
iant
Australia
iant is offline
iant's Avatar
I am checking - re post soon
__________________
Regards
Ian Trost
Old September 15th, 2011, 06:05 AM   #7
iant
Australia
iant is offline
iant's Avatar
Kep server May Help
There is no direct Twido or ABB Driver - But it works
So E/Net Kepserver runs with FActory talk.
you need to set up Modbus over e/Net that requires the IP addresses correctly.
try it it may work
But I googled ABB opc server - some PDF's and othr details available
__________________
Regards
Ian Trost
Old September 15th, 2011, 06:07 AM   #8
iant
Australia
iant is offline
iant's Avatar
Kepserver V4.6 not higher
__________________
Regards
Ian Trost
Old September 15th, 2011, 06:17 AM   #9
Silence89e
Iraq
hmmmmm.... nice idea iant.
i donno if codesys supports KepServer or not,
should i connect the plc online before i connect codesys it to factorytalk??
i will check it out. really thanks iant.
Old September 15th, 2011, 07:12 AM   #10
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
You may want to post this on the CoDeSys forum. They have a specific subject heading subgroup for OPC issues.
http://forum-en.3s-software.com/view...7679d2b42974ae
We use HMIs from Beijer, Exor, Eaton (Microinnovation), and Bosch Rexroth (branded Suetron hardware) to communicate with CoDeSys PLCs. These have drivers that allow you to import the symbol file from your CoDeSys build into the software.
HTB
__________________
nOrM
nOrM=Norman Dziedzic Jr.
I've never been to China but my phone has.
Old September 16th, 2011, 05:25 PM   #11
Silence89e
Iraq
HTB
nice idea ndzied1.... thanx, i'll go and see how it goes.
Old September 17th, 2011, 10:50 AM   #12
shooter
Netherlands
shooter is offline
shooter's Avatar
see you on the 3x site
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Programming an 315 2DP, connecting with an OPC server, Testing a c++ app!! hlvas LIVE PLC Questions And Answers 4 September 21st, 2010 05:15 PM
OPC Server Siemens djpalaz LIVE PLC Questions And Answers 2 October 21st, 2009 06:56 AM
OPC server in FT View SE Abdul_Marlin LIVE PLC Questions And Answers 4 July 8th, 2009 05:36 PM
OPC? Connecting S7-312C - PC. pietervdb LIVE PLC Questions And Answers 6 August 7th, 2008 02:34 PM
citect scada OPC gherz817 LIVE PLC Questions And Answers 4 November 22nd, 2006 05:14 AM
