Reporting Kinetix Error Codes
stephen99
Sep 2011
Perrysburg, OH
We use Kinetix 6000 systems in many different applications and would like to be able to report any drive errors on our front end. The errors I am talking about are the errors that show up on the front of the individual drives on the 7 segment LED. Currently we only get a generic Drive Fault message when an error occurs. This is captured in our Logix 5000 (ver16) program and then reflected in the front end. For instance, if we get an E34 error on a drive we would like to be able to report an E34 error on the front end but currently can only show a Drive Fault. Does anyone know if the error codes are captured by a register either in the individual drives or in the Kinetix module in the Logix rack?
AB has PLC and HMI sample code to display the E errors with discription, how to fix, time and date of occurunce and history. Works great
You could download the AOI's and the faceplates for Kinetix from the download section of Rockwell. The AOI's will return any type of error from a servo drive. There is also an alarm XML file that can be imported into the PanelView. The faceplates are for displaying servo status on a Panelview.
It is called 'How to read K6k 7 Segment Display Fault Code on RSLogix5000'. Go to http://samplecode.rockwellautomation.com/idc/groups/public/documents/webassets/sc_home_page.hcst and select 'Motion Control, integrated' under product family and then select 'Kinetix 6000' as the product.
There is some great information here. It looks like this is for a Sercos Drive. I am using Ethernet/IP drives and although the example is great and exactly what I'm looking for, I can't find an example for Ethernet/IP. Does anyone have any experience with this?
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,015
Hello All, I'm looking for an very simple cost effective OPC application software / any other solution for very simple reporting application. PLC...
1,085
I ran into a strange issue the other day. System has been up and running for many months. An analog input channel suddenly reported 0mA. I...
21
3,294
I need to provide reporting software as part of a project. It needs to be able to auto generate daily, weekly, monthly reports etc. in Excel and...
2,079
Looking for a new reporting software. I wrote this one in 2012 using SQL server and SSRS and I now that I'm getting near the end I need to replace...
2,128
