plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 15th, 2011, 10:11 AM   #1
philoux
Canada
philoux is offline
PowerFlex 70 EC Not React to input and still in Not Enabled
Hi, i recently install a powerflex 70 ec and still saying Not Enabled on the HMI... the safe off jumper is in place and the enlb jumper also. I also try a factory reset but still the same.
all digital input is set to not used exept the input #2 for Run ..... i have no more ideas about that trouble !!1
Thx
Phil
Old September 15th, 2011, 11:25 AM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Look at the parameters for all of the digital inputs and make sure that you don't have another one assigned as enable that isn't wired as such.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old September 15th, 2011, 11:44 AM   #3
bce123
United States
bce123 is offline
bce123's Avatar
also check the jumper wire i have this to be a problem a time or two
__________________
"You can teach a dog to sit and lie down but then he justs gets lazy"
Old September 16th, 2011, 02:33 AM   #4
philoux
Canada
philoux is offline
Check!
I Check the input configuration and all input is set to not used... i also check the jumper for the safe off is on pin 3-4.... but the strange think is is when i apply 24+ on input 6 (TB6) is saying Safe Off on the screen but the jumper is present on the safe off connector ???
Old September 16th, 2011, 03:36 AM   #5
philoux
Canada
philoux is offline
Problem find!!!
I found the problem is located on the main board. Above the Safe Off connector the R108 Resistor blow up !!
Can find only the main board??? for replacement???
Old September 16th, 2011, 03:41 AM   #6
philoux
Canada
philoux is offline
in picture !!!
The Pic of the resistor
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
