plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 15th, 2011, 12:17 PM   #1
ALIMARY15
Italy
ALIMARY15 is offline
PLC DL05 with encoder signals wiring
Good evening,
I am working on a project where i am using a plc DL05 with an encoder to control an axis position.
My encoder signals A and B, i connected them to the input X0 and X1 of the plc because i am planning to use the HSIO MODE 40 for the quadrature encoder as it states into the plc data-sheet.
I have read that this plc doesn't support signals below the 12 V while instead my signals from the encoder are in TTL logic that means 0-5 V.
As anyone of you ever encountered this problem??how you did solve it??
In my case, to make the signal level fine for the plc i have used a IC circuit called ULN2803. This component i connect one pin to the 5 v and the other one to the 12 V power by a pull-up resistor and to the plc as in the scheme showed attached. When from the right pin side there is a signal, the opposite side pin shows zero and viceversa. So in my case when there is 5v to the other side there will be 0v and if i wanna calculate the Pull-up value that will be Rpul= (12V-0v)/max current into plc.
THe component works just fine and it shows to me the quadrature encoder signals between 12V and 0. Now my question is how can i make the plc be aware of the inputs?
It may seem stupid but i am in need in calculating the pull up resistor value in order to make a certain value of current to arrive to the Xo and X1 inputs.
I don't know what is the current value to make the plc read my signals? I have tried to use a current of around 3mA and calculate the pull up value with this current but the plc doesn't seem to read the inputs.
Thanks a lot
Maria
Old September 15th, 2011, 12:28 PM   #2
icky812
United States
icky812 is offline
icky812's Avatar
According to the manual the input needs >5ma to be true. The manual can be found here.
Old September 15th, 2011, 12:40 PM   #3
bce123
United States
bce123 is offline
bce123's Avatar
to solve your problem you could use this: H0-CTRIO I think. it is under $200
__________________
"You can teach a dog to sit and lie down but then he justs gets lazy"
Old September 15th, 2011, 01:23 PM   #4
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
A 600 ohm pull up should give the 5 ma at 12 VDC.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old September 15th, 2011, 02:05 PM   #5
JeffKiper
United States
JeffKiper is offline
JeffKiper's Avatar
Bernie have you been down that road before? it sound like you may have been there.
I know the math works out as well.
__________________
There should be a minimum IQ before people can breed.
FS Eng (T‹V Rheinland, #11004/15, Machinery)
Old September 15th, 2011, 02:14 PM   #6
bernie_carlton
United States
Also, 1/4 watt would be on the edge (12 volts across the 600 ohms). Better to use at least 1/2 watt resistors as pull-up.
__________________
www.thePLCguy.com
Old September 16th, 2011, 04:06 AM   #7
ALIMARY15
Italy
Quote:
Thanks I have also the h0-ctrio but we wanted to try to simply use the dl05 module without programming the ctrio module
Old September 16th, 2011, 04:07 AM   #8
ALIMARY15
Italy
Quote:
Thank you so much! Im gonna try with 600 Ohm resistance. Do you think that also a 1.2 K will work?
Old September 16th, 2011, 07:54 AM   #9
bernie_carlton
United States
600 ohms provides 5 ma into the input impedance as listed for the module. Of course you can try anything you want but 600 ohms is the result of the calculation. Two 1.2 K in parallel would also work.
__________________
www.thePLCguy.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Encoder and PLC logic SCAN.PLC LIVE PLC Questions And Answers 12 March 27th, 2017 10:57 PM
How do i use the S7-300 plc with encoder, motor and drive to control motor position Shadley LIVE PLC Questions And Answers 4 October 1st, 2009 07:55 AM
Hard wiring the PLC Doug Hylton LIVE PLC Questions And Answers 46 October 23rd, 2007 01:21 PM
connect an encoder to omron plc hadiahmadi5 LIVE PLC Questions And Answers 14 August 20th, 2007 08:45 AM
absolute encoder with S7-200 plc: suganya LIVE PLC Questions And Answers 0 April 9th, 2007 12:37 AM
