This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Aug 2010
Automatically running a rs view 32 project
Anybody please advice me how we can run a rs view 32 project with windows XP starts(when computer turns on)
#2 |
Basically you may add RSView32 to the StartUp folder in Windows XP.
See the RSView32 Runtime User Guide, chapter 2, starting page 2-3: Starting RSView32 Runtime automatically http://literature.rockwellautomation...m001_-en-e.pdf There are informations also at page 18-14 of RSView32 USER’S GUIDE: http://literature.rockwellautomation...m001_-en-e.pdf - fuzzy logic Last edited by fuzzy logic; October 11th, 2011 at 10:49 AM. Reason: added a second reference for the user's guide |
#3 |
![]() Join Date: Aug 2009
srv,
Create a shortcut with something like this and stick in the XP start folder. "C:\Program Files\Rockwell Software\RSView\rsvrt32.exe" "C:\ProjectFolder\Project.rsv" /r It's also in the manual..... |
#4 |
One last tip: If you want it to run with the window fully maximized then right click the short cut in Windows, choose properties, and change Run drop down selection from "Normal Window" to "Maximized"
__________________
True craftsmanship is only one more power tool away. That's the beauty of processors, they don't have emotions they just run code - The PLC Kid. |
#5 |
Thanks for all replies.How i can directly run the project by clicking rs view 32 icon on the desktop screen.I just tried to run through rs view 32 runtime.Through that we need to select the project and run it manually.I just need to add a project shortcut on the desktop and need to run the project by clicking that icon.please advice me,how we can do that
#6 |
Ok...here we go again!
Create a shortcut on your desktop instead of the start folder containing something like this.... "C:\Program Files\Rockwell Software\RSView\rsvrt32.exe" "C:\ProjectFolder\Project.rsv" /r ????? |
#7 |
Hmmm, apparently Srv's problem is deeper than we thought....
1. From the Windows XP Start box (normally located in the lower left corner of your screen), RIGHT-click on "Start", then select "Explore". 2. Using Windows Explorer, browse to your RSView project folder, open it, then find the *.rsv file (Your RSView Project Name.rsv). RIGHT-click on the rsv file, then select "Send To", then "Desktop (create shortcut)". 3. You are done! |
#8 |
![]() Join Date: May 2010
What would be the use of that?
#9 | ||
Quote:
Quote:
#10 |
Thanks.I just tried that.shortcut created.But when i click on shortcut icon,rs view works with project manager window opens and need to run from there.my doubt is, can we run the project (with out project manager and click on run)direct from the shortcut.I mean when we click on shortcut initial graphics should be opened.anybody pls advice me
#11 |
This is as easy as it gets....really.
"C:\Program Files\Rockwell Software\RSView\rsvrt32.exe" "C:\ProjectFolder\Project.rsv" /r 1. C:\Program Files\Rockwell Software\RSView\rsvrt32.exe = the path to RSview32 Runtime executable. 2. C:\ProjectFolder\Project.rsv = Your project path and the "rsv" file for your project. You will have to change the name and path to suit your needs. 3. "/r" runs the project when it opens. 4. So to put this all together left click on your desktop create a short cut and paste the above path into the properties. It's that easy. The easiest way to open on a specific graphic is to open the project in Works click on Startup (the little green flaggy thing) go to the start tab and check "Intial Graphic" then select your desired screen to open at start. Do you not have a manual?? |
#12 |
Thanks..jac
#13 | ||
Quote:
Quote:
1. From the Windows XP Start box (normally located in the lower left corner of your screen), RIGHT-click on "Start", then select "Explore". 2. Using Windows Explorer, browse to your RSView project folder, open it, then find the *.rsv file (Your RSView Project Name.rsv). RIGHT-click on the rsv file, then select "Send To", then "Desktop (create shortcut)". That is all, two easy steps, no typing of long strings of characters for us poor typists, and a shortcut icon that opens exactly the file that you pointed at. If you want the project to RUN instead of just open for editing, then you can manually add the "/r" at the end of the shortcut Target string. Last edited by Lancie1; October 21st, 2011 at 05:28 PM. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Decimal point in RS View 32 Trend! | paul_36 | LIVE PLC Questions And Answers | 6 | September 28th, 2010 12:12 PM |
| RSView 32 vs. View SE/ME | Christian Dam | LIVE PLC Questions And Answers | 9 | October 20th, 2008 06:20 AM |
| RS View with RS messenger ver 6.3 | joesullivan8 | LIVE PLC Questions And Answers | 1 | June 19th, 2007 05:03 PM |
| HELP with RS View 32 and CLX | Ashwin | LIVE PLC Questions And Answers | 3 | March 14th, 2004 12:20 AM |
| RS View 32 - MicroLogix 1500 - ENI Module | bmtrash | LIVE PLC Questions And Answers | 2 | December 18th, 2003 09:57 PM |
