This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Guest
Posts: n/a
Hi all Masters,
Right now I'm learning RSview 32. I can make a tag for a bit, I drop a push-button from library. I can use toggle command to make it on or off, but you know, when we turn on or off a motor, normally we can't toggle it, we need a push-button for on, another for off. Could you please tell me how to make the bit action momentarily? Thanks. Shawn |
#2 |
Guest
Posts: n/a
The logic in the PLC should be a classic start/stop control circuit, ie: N.O. start PB, N.C. stop PB and N.O. latching contact. The pushbuttons in View should operate just as a mechanical switch would.
#3 |
![]() Join Date: May 2003
When you double click on a button for editing the button configuration screen should appear and from there you can select momentary.
Also, not sure if I understand you correctly but you can make your own push buttons using the drawing toolbox (instead of going to the library all the time). Go to View up in the main toolbar and check Drawing Toolbox. On mine, it is the last one to the right. It is a rectangle with a finger. Bob O |
#4 |
Guest
Posts: n/a
Thanks!
Thanks for the replies. Shawn |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| To Latch Or Not To Latch | BOWRIDER | LIVE PLC Questions And Answers | 36 | November 6th, 2004 04:30 PM |
| Flying windows button for RSView32 security | Deer | LIVE PLC Questions And Answers | 6 | February 4th, 2004 10:12 AM |
| using ^C in BASIC module | ettikudiappan | LIVE PLC Questions And Answers | 9 | November 24th, 2003 09:10 AM |
| Toggle switch & Push button switch | m_abd_el_khalik | LIVE PLC Questions And Answers | 4 | November 2nd, 2003 09:51 AM |
| single push/ double push variation using mitsubishi FX1N | taknevs | LIVE PLC Questions And Answers | 20 | April 15th, 2003 06:17 AM |
