plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 26th, 2011, 08:43 PM   #1
jeramiah
United States
jeramiah is offline
jeramiah's Avatar
getting a siemens plc system to talk over wifi
Hi all,
I am trying to get a Siemens 315-2 PNDP PLC and a Siemens ET200M (153-4) Profinet system to communicate to each other over wifi (I am using a MOXA AWK-3121-US wireless switch. however I am having a difficult time getting it to work. I can ping to each devices ip address. but when i view the siemens hardware config, it says the IM153-4 is configured but not available. If i connect directly to the PLC and the IM153-4 with a CAT5 cable, it will communicate just fine.
Is there some setting that I am missing?
any helpful remedies are welcomed.
Thank you
Old October 27th, 2011, 03:15 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
I am not an expert in wireless Profinet, but I think that you need Profinet-rated wifi equipment in order for it to happen. And it must be configured so that the topology is known throughout the project.
__________________
Jesper
See my profile interests for Q&A
Old October 27th, 2011, 03:57 AM   #3
Manglemender
United Kingdom
Manglemender is offline
I've never tried Profinet over WiFi but I have used standard ethernet switches rather than Siemens switches. I think that the topology only needs to be defined if you are using some of the higher level protocols such as IRT.
Does the switch contain a firewall/packet filter and, if so, is it rejecting traffic to and from slave address? Is the switch set up for IP Spoofing / "Network Translation"?
I'm interested to know the solution to this one.
Nick
Old October 27th, 2011, 04:10 AM   #4
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
I've seen a MOXA AWK-3121 working with an S7 PLC + ET200S but unfortunately don't have details of the MOXA configuration.
Old October 27th, 2011, 06:40 AM   #5
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Quote:
"Regular" TCP/IP I have done many times over wifi.
And wired (not wifi) Profinet IO RT (not IRT) is possible with any switch that supports QoS.
__________________
Jesper
Old October 27th, 2011, 03:49 PM   #6
WJhsson
Sweden
WJhsson is offline
WJhsson's Avatar
I have no experience on the MOXA products, but you may have some kind of protocol problems which is not affecting the ICMP protocol (which the PING command uses).
What you could do is to try to adjust (increase) the "update time"-parameter in HW-config from default 1 ms to 8 or 16 ms. You find the parameter by double-clicking the slave. Not sure if it helps you out, but it could be worth to try.
__________________
Old February 8th, 2018, 12:34 AM   #7
drmandge
India
drmandge is offline
Hello,
Even I am also trying to achieve the same. I can ping my ET200M but CPU is not detecting any ET200M connected to it. Did u find any solution so far?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens S7 – 300 PLC and WinCC Flex 2007 HMI peng LIVE PLC Questions And Answers 3 March 17th, 2011 04:13 AM
Starting a New Siemens System JiNCs LIVE PLC Questions And Answers 3 November 15th, 2010 05:17 AM
Communication Between siemens S7 400 PLC and Abb AC800 PLC Asim Shahzad LIVE PLC Questions And Answers 3 October 30th, 2008 03:54 AM
Siemens PLC PID Problem dutchkg LIVE PLC Questions And Answers 0 October 21st, 2008 06:11 PM
Siemens S5 / Westinghouse PC503 PLC Rhopac LIVE PLC Questions And Answers 2 September 15th, 2008 08:07 AM
