plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 14th, 2011, 01:46 PM   #1
funfun66
Germany
funfun66 is offline
PLC software testing
Hello...
Can anyone suggest me what are different methods used for testing PLC software. also where can i find tools for PLC software testing.
regards..
funfun66
Old November 14th, 2011, 06:23 PM   #2
KalleOlsen
Norway
KalleOlsen is offline
Quote:
Originally Posted by funfun66 View Post
Hello...
regards..
funfun66
Simulators?
No particular PLC type in mind?
Kalle
Old November 15th, 2011, 04:34 AM   #3
funfun66
Germany
funfun66 is offline
Hello...
I want to know apart from simulators what are other methods.
there is no particular type..i need it generally for all.
also please tell me what are the tools available for these and where can i find it.
Regards
funfun66
Old November 15th, 2011, 05:17 AM   #4
funfun66
Germany
funfun66 is offline
Also programming language used is structured text.
Old November 15th, 2011, 11:11 AM   #5
RussB
United States
RussB is offline
RussB's Avatar
Syntax checking should be part of your developer, other than that the only reliable method I know of is to have an expierenced Engineer review the code. Short of this all testing is either on a simulator or at commissioning.
May be a good project for an industrious and creative programmer.
1. In put the process sequence of operations.
2. Add BOM.
3. Read the logic.
4. Verify end results.
Sounds simple enough.
Would you need verbal or ASCII input for this and would you want the output UL and CE certified?
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Old November 15th, 2011, 11:14 AM   #6
KalleOlsen
Norway
Hello...
Regards
funfun66
Aha, you want a magic tool that analyzes whatever program you write?
Well, then we are two.
Kalle
Old November 20th, 2011, 05:18 PM   #7
V0N_hydro
Canada
V0N_hydro is offline
Kalle
I have written a program that analyzes the PLC program. It makes sure all IO is used in the program, and generates tables of constants, operator settings, event/alarm/trip conditions, and documents the interface between the PLC and HMI. It saves me from having to update documentation if the program has to be changed, and saves me from generating these specifics in the first place.
I recommend creating a good convention and structure for the parts of the program you want to automate the documentation or test-plan generation for as the program you write to parse your program will only be as good as you are at following the convention you create.
Old November 21st, 2011, 05:54 AM   #8
funfun66
Germany
funfun66 is offline
hii..
thank u all for your replies and suggestions.
but can you tell me wat is difference between virtual commissioning and simulation, as i find that both are doing same job.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ab plc software indra LIVE PLC Questions And Answers 5 July 28th, 2010 03:35 AM
S7-300 Software Redundancy DB Transfer to RESERVE PLC halburgepramod LIVE PLC Questions And Answers 1 June 22nd, 2007 12:41 PM
Software Utility to Map PLC Network Bus Topology mbd0722 LIVE PLC Questions And Answers 1 May 31st, 2007 10:00 PM
Taylor Industrial Software blawrenz LIVE PLC Questions And Answers 6 August 14th, 2006 12:32 PM
keyence PLC software stef168 LIVE PLC Questions And Answers 1 September 8th, 2004 10:13 AM
