plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 23rd, 2011, 04:20 PM   #1
DairyBoy
Wales
DairyBoy is offline
comms errors with PV+ and L32E
Setup: PV+1000 (V5.10), 1769L32E processor (V19.11). The two units communicate, the devlopment version sees all the RS5000 tags as they are created but the PV shows runtime errors like "Item '{[Silo_Routing]B1[21]' is unresolved in the processor on route Compactlogix in slot 0... I can read numberic variables on the screen, all the colour change and visibility attributes work, but any bit addressed tags generate errors like "Write attempt for item '[Silo_Routing]HMI_Switches[5]' failed (configuration error) on compactlogix... etc. The same happens if I run the application on the pc. What have I missed this time, dudes??? Thanks.
Old November 23rd, 2011, 04:23 PM   #2
bce123
United States
bce123 is offline
bce123's Avatar
can you post the files?
__________________
"You can teach a dog to sit and lie down but then he justs gets lazy"
Old November 23rd, 2011, 05:12 PM   #3
DairyBoy
Wales
DairyBoy is offline
Thanks for the offer but they're still over a meg zipped. So much for zipping.
Old November 23rd, 2011, 06:06 PM   #4
ianingram
Australia
ianingram is offline
Quote:
You said bit address...
Is that the correct address?
Or is the address something like
[Silo_Routing]HMI_Switches[5.0]
Old November 23rd, 2011, 06:10 PM   #5
DairyBoy
Wales
DairyBoy is offline
Ian, "HMI_Switches" is a DINT, so [n] is the bit number within that DINT. I've checked the format against my only other 5000/PV+ project and the format is the same.
Anyway, third late night in a row on this one and eyes/brain are stuffed. Simplest plc prog I've ever written and it's giving me more grief than some of the bigguns. crazy. Time for bed. Delivering it tomorrow...
Old November 23rd, 2011, 07:32 PM   #6
Ken Roach
United States
Ken Roach is online now
Ken Roach's Avatar
Square brackets denote a member of an Array Tag (BOOL, SINT, INT, DINT, REAL, STRING, etc)
A period denotes a bit sub-element of a SINT, INT, or DINT Tag, whether it is an array member or an ordinary atomic datatype.
If the Tag is a DINT, then MyTag.x is the syntax for a bit sub-element in that DINT.
If the Tag is a DINT array, then MyTag[y].x is the syntax for a bit in that array element.
If the Tag is a BOOL array, then MyTag[x] is the syntax for a bit in that array.
Old November 23rd, 2011, 07:37 PM   #7
ianingram
Australia
I was hoping that someone else would reply by now...
I am looking at projects that I have done, and the addressing format is [shortcut_name]tagname.bit_number
I am guessing that you are missing a . in your address format
Old November 24th, 2011, 03:40 AM   #8
DairyBoy
Wales
DairyBoy is offline
Ken, Ian, you're both right. I've looked at the previous PV prog as a reference without sufficient care regarding the data types in the plc prog. I need to change the data type in the hmi. My mistake. Thank you.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PV 600 and L32E Daylight Savings Time Change agrosse LIVE PLC Questions And Answers 6 November 9th, 2011 12:26 PM
Cannot ping L32E mutabi LIVE PLC Questions And Answers 19 August 2nd, 2011 12:48 PM
