This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Oct 2010
Location: Where the devil lost his "Poncho" (in the back of beyond)
Hey, maybe this is a little too obvious for most of you, but I had a problem today where I needed an extra digital output in my PLC and I had none free. I couldn't wait nor afford to buy an additional I/O module, so I came with this idea ( Nothing revolutionary but...)
As most relays have 4 NO/NC contacts, I used 2 of them connected in series as the scheme in the pic shows and with only 2 digital outputs controlling them I can manage 3 physical outputs ( )The disadvantage is that you cannot have 2 outputs ON at the same time, but maybe this is not a problem for your application, as it was not in mine. A little dumb? Well, maybe...but it saved my day! Enjoy...
__________________
"Everything crumbles, sooner or later" Elton John |
#2 |
Just be sure to document what you did and why. Next person that comes behind you to do any programming related to the outputs will be confused otherwise.
I would suggest that you put the addition of an output card on your list of things to do.
__________________
Artificial intelligence never overcomes natural stupidity. |
#3 |
TWO WORDS....POOR PRACTICE.
I'm assuming that the PLC outputs are digital and your relays must be mechanical. One failure of a relay brings down all three outputs. Also very difficult to troubleshoot let alone understand. In three words...don't do it. Or if you've done it. Undo it. |
#4 |
Thanks for your comments...
I know it's not a good reliable solution. I know that as NICK B said it can be considered as Poor Practice (It's almost like going back to hard-wired control panels), but what would you have done? Can you share some other alternative? I did this because as I said I needed to leave the equipment working yesterday and I couldn't wait to buy an extra module (things usually take between 2-4 weeks to arrive to where I work), so that was a solution I came up with in despair. I know it's not the smartest thing I've donde so far, but it is a solution and that is what we get paid for. So, while I wait for the extra I/Os to come, this will be working ok, and everyone in maintenance is aware that if something on those 3 outputs fail, the first thing to do is to check those 2 relays. Thanks again, but honestly, I'd like to hear what other options I had in a case like this.
__________________
#5 |
![]() Join Date: Feb 2008
I didn't really follow your drawing but I understand that you have basically used the fact that both outputs are on as an 'extra' condition with which to control something.
As others have commented, this is going to be quite difficult to fault find on so I hope you have made sure the drawings and software are well documented. I understand your reasoning behind it (i.e. unable to get an output card quickly enough etc) and I think it was very resourceful of you. Between your solution or the production line being off due to a lack of an output then I would choose your solution every time. As has already been mentioned though, I would retrofit a new output card as soon as possible and put the configuration back to how it should be. ;-) |
#6 |
![]() Join Date: Mar 2009
Good work around but like others have said, make a point of getting a new O/P card installed... what you going to do if you need 4 outputs ?
Just make sure you leave adequate information for others that may have to do work on the equipment !! Regards JV |
#7 |
Supporting Member
![]() Join Date: Nov 2006
Spookily I have just used this method. I had 8 PLC outputs that had to control 12 contactors.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| PLC and RIO I/O | The Plc Kid | LIVE PLC Questions And Answers | 1 | December 13th, 2010 05:46 PM |
| S5 I/O S7 PLc | hooman | LIVE PLC Questions And Answers | 3 | February 28th, 2007 01:51 AM |
| Adding DP to an S5 PLC rack using IM308C | clmview | LIVE PLC Questions And Answers | 1 | May 13th, 2006 10:18 AM |
| PLC I/O Status Trending | STAN12 | LIVE PLC Questions And Answers | 2 | April 19th, 2004 05:59 AM |
| Mitsubishi PLC <> Profibus I/O modules | pawelleg | LIVE PLC Questions And Answers | 4 | March 5th, 2004 09:57 PM |
