plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 26th, 2004, 01:26 PM   #1
NoName
Slovenia
NoName is offline
NoName's Avatar
Question MM420 speed problem!!!
Hello all.I'm working with C7635 OP, and a micromaster 420 inverter.And when I try to send the speed setpoint something weird happens. If I send 2000, the frequency is set to 50% that is 25HZ.But if i Try to send 1900 to the inverter as the speed setpoint, it should be around 40% so some where around 22Hz, but it's not it's 19,8 HZ. How come that i can't set the speed setpoint no where around 20 to 25 HZ???Have any of you had this problem, so any advice would be helpfull.Do I just have to set somekind of parameter or what??? Please help me.
Thank you.
>Aleš<
Old January 26th, 2004, 02:03 PM   #2
Tom Jenkins
United States
Tom Jenkins is offline
Tom Jenkins's Avatar
I don't know your PLC, but it looks to me like your analog output is 12-bit. That means that 0% output is 0 data, and 100% output is 4095 data.
You don't say, but I suspect that your output is 4-20 mA. Make sure the drive and the output are both set for 4-20 mA. One of them may be 0-20 mA.
Another thing to check is if the VFD has been set to skip certain frequencies. Sometimes, to avoid critical frequencies and vibrational resonance, the VFD is set up to not operate at certain speeds.
Old January 26th, 2004, 02:35 PM   #3
NoName
Slovenia
NoName is offline
NoName's Avatar
Sorry, but I forgot to tell that I'm comunicating with the drive via Profibus.No through any analog inputs/outputs or something like that.Sorry it's been a long day and i'm starting to forget stuff.
>Aleš<
Old January 26th, 2004, 06:18 PM   #4
The Dark Knight
United States
The Dark Knight is offline
The Dark Knight's Avatar
Hmmm
It depends on the format (word or decimal) you are using
When I do my calcs, I get 19.53 Hertz..
if 1900 is transmitted as a word.
Here's what I got
1900Hex -> 6400Decimal
100%= 16384Decimal = 4000Hex
6400Decimal / 16384Decimal * 50Hz=19.53Hz
You can not just say 1900Decimal / 4000Decimal*50Hz=X
You will get the wrong answer
Old January 26th, 2004, 08:09 PM   #5
dchartier
Canada
dchartier is offline
Hello, NoName;
Dark Knight has a valid point. You need to write the speed setpoint values in hexadecimal format to the Profibus address selected.
Say your speed setpoint register address has been selected to PQW258;
then MOVE the hex value you want to that address:
in STL, it would look like
L W#16#4000
T PQW258 // requesting 100% of max. speed parameter
L W#16#2000
T PQW258 // requesting 50% of max. speed parameter
L W#16#1900
T PQW258 // requesting 47.5% of max. speed parameter
Hope this helps
Daniel Chartier
Old January 27th, 2004, 12:57 AM   #6
NoName
Slovenia
NoName is offline
NoName's Avatar
I am sending it as a word(HEX) to the inverter, so I realy don't know why it doesn't work like it should. Is it possible that a parameter could be set wrong???
Here is how I send the speed setpoint.
NW1
A(
A M 124.4
A M 28.5
JNB _01d
L W#16#1900
T PQW 258
SET
SAVE
CLR
_01d: A BR
JNB _01e
L W#16#47F
T PQW 256
_01e: NOP 0
Hope this helps.
Thank you.
>Aleš<
Old January 27th, 2004, 03:37 AM   #7
The Dark Knight
United States
what i'm saying is that you should get close 19.5Hz. You say that you are getting 19.8, so the drive is responding properly.
Old January 27th, 2004, 09:15 AM   #8
NoName
Slovenia
NoName is offline
NoName's Avatar
No it's probably 19.5, I just wrote that value from the top of my head.Sorry. So what you are saying is, I can't set the speed no where around 22HZ or is there a way??
Thank you.
Old January 27th, 2004, 09:39 AM   #9
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
Of course you can set the speed to 22 Hz.
22 Hz / 50 Hz = X / 16384
X = 7209 decimal = 1C29 hex
Even if you're limited to steps of 100 counts, there are still six steps between 1900 and 2000 hex;
1900 = 19.53 Hz
1A00 = 20.31 Hz
1B00 = 21.09 Hz
1C00 = 21.88 Hz
1D00 = 22.66 Hz
1E00 = 23.44 Hz
1F00 = 24.22 Hz
2000 = 25.00 Hz
Old January 27th, 2004, 10:12 AM   #10
NoName
Slovenia
NoName is offline
NoName's Avatar
Smile
AAAAAAAAAAAAA. I was thinking in a totaly diferent direction.I totaly forgot that i was sending a HEX value,to the inverter.I just thougt that 1900 is around 23Hz,I wasn't thinking right.Thank you all for all your help,as you can see sometimes I have tunnel vision. Thanks to ALL!!!!
Old January 27th, 2004, 11:14 AM   #11
JRW
United States
JRW is offline
JRW's Avatar
Another tidbit-
If you want to see your profibus value sent to the drive-
Look at
r2050.0- Control word from your master (in decimal)
r2050.1- speed value from your master (in decimal)
r2050.2- Spare
r2050.3- Spare
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Using a proximity switch to detect speed Beej LIVE PLC Questions And Answers 22 December 8th, 2011 05:21 AM
ac drives lumbee 100 LIVE PLC Questions And Answers 8 February 8th, 2006 01:10 PM
50HP DC motor to AC !!! Pierre LIVE PLC Questions And Answers 26 October 18th, 2004 02:47 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
PLC5/40 Backplane Problem????? Andrew Evenson LIVE PLC Questions And Answers 18 August 24th, 2002 07:06 PM
