plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 20th, 2011, 06:54 PM   #1
saltykarp
United States
saltykarp is offline
Help! Anyone knows information about GE Fanuc PLC
Hi all -
I have a project where I will replace a GE Fanuc PLC, with Allen Bradley hardware.
This PLC looks very old and I do not know much about it. I want to see if there is a way to use the Ethernet line to upload the code that is already on that PLC. Is this possible? If so, what software is the programming language in, and how would I upload it?
Old December 20th, 2011, 07:12 PM   #2
jrwb4gbm
United States
jrwb4gbm is offline
It should be possible to upload the code. LogicMaster90 (DOS based) is most likely the old software it was programmed with. I don't know about using ethernet for this. Normally you would use a SNP adapter to connect to a real serial comm port on your computer. It would be a big help if you could list the exact model numbers for everything including the I/O modules, chassis, (backplane), etc. Is it currently networked to an HMI or another PLC?
There are others on the forum much more knowledgable about this PLC than I am. I'm sure someone else will jump in to help soon.
Edit: Thanks Steve, you're right, I was thinking about the Series 90. I don't know why I didn't think of the others, must be getting old.
Old December 20th, 2011, 07:56 PM   #3
Steve Bailey
United States
Steve Bailey is online now
Steve Bailey's Avatar
GE Fanuc marketed quite a few models of PLC over the years. Some of them had ethernet connectivity, some didn't. Different models require different software. Unless you tell us which model PLC you're looking at, nobody is likely to offer much help.
jrwb4gbm is making an assumption that you have a Series 90 PLC, but for all I know you could be looking at a Series One, Series Six, Series Five, or Series Three.
Old December 20th, 2011, 08:13 PM   #4
saltykarp
United States
I have a 90-30
Old December 20th, 2011, 08:38 PM   #5
Steve Bailey
United States
The Series 90 came out in 1990. Until around 1999, the programming software was DOS-based Logicmaster 90. After that there was VersaPro followed by Proficy Machine Edition. Earlier releases of Proficy Machine Edition were also called Cimplicity Machine Edition.
All Series 90-30 have a serial port on their power supply.. It's RS485, so you'll need a RS48/RS232 converter to connect to a real serial port. It's also possible to use a USB/serial converter, but they can be finicky.
For ethernet connectivity you will need either a CPU module with an ethernet port or an ethernet communicatins module in one of the I/O slots.
Old December 20th, 2011, 08:42 PM   #6
Davev2005
Mexico
Davev2005 is offline
Please check the next link in order to review if your CPU it's ethernet compatible.
http://plccompare.com/wp-content/upl...1/GE-90-30.pdf
We using Proficy Machine Edition with this PLC's thru ethernet without any problem.
Old December 20th, 2011, 09:10 PM   #7
Steve Bailey
United States
That brochure in the link is dated 1998. Of course, it's possible it was current when the OP's PLC was new.
Old December 21st, 2011, 11:10 PM   #8
03hdfatboy
United States
03hdfatboy is offline
You should have no problem using LM90 to upload the data off the old GE,and print it. I've done it and I am a far cry from a PLC "Pro"
Old December 22nd, 2011, 08:29 AM   #9
RussB
United States
RussB is offline
RussB's Avatar
For more information on what serial cable to use, try this.
__________________
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question promotes DETAIL in my answer.
Dominus Vobiscum <))>(
"Where is the wisdom that we have lost in knowledge?" T.S. Elliot
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ge Fanuc Plc sanket_shete LIVE PLC Questions And Answers 15 August 24th, 2005 04:30 AM
GE Fanuc PLC Redundant Modbus serial slaves August LIVE PLC Questions And Answers 1 July 13th, 2005 10:31 AM
GE fanuc PLC & Temprature controller harshad LIVE PLC Questions And Answers 1 July 1st, 2005 09:42 AM
Series one GE Fanuc plc rs232 interface maca LIVE PLC Questions And Answers 4 April 22nd, 2004 06:15 PM
